Hi guys,your help is very appreciated, i cleaned my rx330 engine with a cleaner ,now there is like streak discoloratin on the silver engine cover,the black plastic is very rough looking and even the black frame looks dicolored.Any suggestions please
it may help if you tell us what cleaner(s) you used. it is possible the cleaner you used may have been to abbrasive and has actually damaged the plastic covers
Always test that stuff in a small spot first. Some stuff will discolor your plastic or change the texture of it. it was probably too harsh or the motor was hot when you sprayed on it and its "burned" in now =/
thank you for the replies,it is foamy ,donot know about the composition,the motor was cold.
I took the plastic cover off,cleaned it and planning to repaint it,,if you have any suggestion about the paint itself or the color tell me please
Primer and High temp paint. Paint it whatever color you wish.
You can also use some clear coat if you wanted to.
