Meguiar carnauba wax or Zaino: What lasts longer?
Zaino no contest. Zaino is probably the longest lasting car sealant I have ever used, only Colinite 476S seems to last as long from my experience. Mequiars waxes and sealants don't seem to last very long at all in my experience.
most sealants are durable
what I choose is based on looks and ease of application so Wolfgang Deep Gloss Paint Sealant and Menz powerlock...
I also broke down and got Chemical guys blacklight... still testing it though...
You can only really buy Zaino directly from Zaino so it is a bit pricey. All you really need is the ZAIO as a base and then Z2 or Z3 for added gloss/protection. Z8 is a good detail/gloss spray too. With Zaino you need to make sure your finish is completely clean of previous wax/polishing oils, and anything else because it is sensitive and may not adhere properly if it is not clean, you also need some kind of base first like ZAIO before you can put other products on like Z2/Z3 for it to properly work. I have been extremely impressed with the longevity and protection of Zaino products and I have tried many different kinds of waxes/sealants.
Collinite is also very durable and lasts a long time also so don't expect Zaino to blow it away but I still find Zaino seems to last a little bit longer.
http://www.zainostore.com/Merchant2/...ory_Code=Zaino
You can only really buy Zaino directly from Zaino so it is a pricey. All you really need is the ZAIO as a base and then Z2 or Z3 for added gloss/protection. Z8 is a good detail/gloss spray too. With Zaino you need to make sure your finish is completely clean of previous wax/polishing oils, and anything else because it is sensitive and may not adhere properly if it is not clean, you also need some kind of base first like ZAIO before you can put other products on like Z2/Z3 for it to properly work. I have been extremely impressed with the longevity and protection of Zaino products and I have tried many different kinds of waxes/sealants.
So for a clearcoated car I'd get the ZAIO and the Z2?
What's the best way to apply it? First do a coat of ZAIO, let it haze, buff off, and then top it with the Z2? How many coats of Z2 do you need?
Now I am confused. When you said I need ZAIO as a base... what do you mean? I read it's an all in one product that apparently decontaminates (why would they have the clay bar then haha), polishes, and protects.
Do I really need that since I clay my own cars and do my own machine polishing? I'm just looking to try out a new durable wax because I am bored. Can I just go straight to the Z2 after a machine polish and final IPA wipe-down?
The ZIAO lays a base chemical foundation that the Z2 or Z3 or other Zaino products adhere/bond to. Z2 or Z3 by itself is not going to adhere properly to your finish without a base like the ZIAO applied and wiped off first. ZIAO also has some very minor ability to polish and "clean" the finish like most AIO as well as provides a base coat of protection. The Z2 adds more protection and gloss. You need the ZAIO regardless if you clay your car or not for the Z2 or other Zaino sealants to properly adhere, it is at least a 2 step process. I use 2 coats of Z2 after adding/wiping off the ZIAO base. I also use the Z8 spray between coats of Z2. Don't worry too much about the price as the ZAIO and Z2 is going to last a very long time, you don't need to add much of either product, light coats are better.
One, apply Z2 (or Z5) with the added ZFX catalizer
Two, apply ZAINO first then Z2 (or Z5).
If you are machine polishing the paint, Z-AIO is not going to offer much of a benefit (in terms of shine). In this case I would go with Z2/ZFX for up to three coats and call it quits.
Two options.
Daniel2311
Automotive Care & Detailing
08-06-15 04:34 PM
SGT
11-06-05 03:29 PM
