Bumper Marr from Accident
Long story short, I got into an accident in a parking lot, and my bumper has a slight marr which is shown below. I have a witness, there is a good chance that it will be the other drivers fault, and a new bumper is an option too. That being said, both insurance companies appear to be hammered with other claims so I could be driving around with this for a few weeks.
![](https://i210.photobucket.com/albums/bb21/Raralith/lexusaccident05-15-2011.jpg)
I felt the area and there definately is a small depression into the bumper as if a small piece was gouged out. Is there anything I can do to fill this, and buff out the outlaying scratched area? I'd also rather get this fixed quickly if it can be done well since I consult on the side, and it normally involves driving clients in my car (dinner, on site inspections, etc...) so I don't want to show up in a Kia xyz or Toyota Corolla.
if you have a buffer most of that will come out except for the depression (the paint is missing in that spot)
If working by hand, get some scratch X 2.0 and rub it in well with a foam pad. Might have to do it a few times to make it less noticeable. You can throw some touchup paint on the missing area but it should hardly be noticeable since the car is black and so is the underlying plastic of the bumper.
If you are around the Irvine area, shoot me a PM and I'll give you a hand. Otherwise, its fairly straightforward to correct. I'd start with Ultimate Compound since I know the level of cut of ScratchX 2.0 isn't that much. UC also finishes down pretty well too so that is another plus
Scratch X 2.0 uses the same SMAT technology that is in UC, there is just a bit less of the abrasives so they all finish down the same.
http://www.autogeekonline.net/forum/...prise-you.html
Would the same technique help me clean up a huge scratch on the underside of my front lip? I scraped real hard on one of those concrete bars in parking spots while trying to park. Rolled it too far forwards
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
ouch
UC will take off some of the marring but you've lost a lot of paint there. Only touchup will help I'm afraid. Buff it with orange pad and UC to see what you can get out then go to town with the touchup paint (apply it thin and build up the coats til you are slightly above surrounding paint. Wait a week then soak some 2500-3000 unigrit in water overnight then wetsand it level and buff again with UC.
or get a lip...
or get a lip...
Thanks for the tips ya'll. I picked up the Meguiar's Ultimate Compound with a foam pad for hand use. Hopefully I'll have some decent before and after shots.
Did some work, here are the results.
I cleaned it up with some quick detailer:
![](http://i210.photobucket.com/albums/bb21/Raralith/Cleaned.jpg)
I used the Meguiar's Ultimate Compound with a cotton terry pad, and put a bit of pressure passion into it:
![](http://i210.photobucket.com/albums/bb21/Raralith/Polished.jpg)
I than applied some touch up paint, purchased from Sewell and using the correct color (SMG), but wow, that's so light! It says it will take 30 minutes to harden so I hope it darkens too.
![](http://i210.photobucket.com/albums/bb21/Raralith/TouchupPaint.jpg)
I'll be quite honest, I'm pretty sure I did a bad job with the touch up paint. I used the MUC again on the touchup paint and it's a bit more flush. If it does not darken more, does anyone have any more advice? I'm thinking of possibly taping off the area and sanding it a bit to smooth out the touchup paint. Any thoughts?
