Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Engine cleaning procedure
Old 06-10-11, 10:29 AM
techtalk
techtalk's Avatar
Default Engine cleaning procedure
Hey guys,
I recently detailed my dirty IS300 engine and would like to share a brief engine-detailing D.I.Y. procedure with you all:
1) Move the car to an area where the soap and material cleaned off will not cause damage or enter a storm drain.
2) If you do not have access to a suitable location, take the vehicle to a car wash with an industrial wastewater treatment system. This is especially important if there is a lot of oil and sludge residue on the engine.
3) Remove the negative terminal cable on the battery then the positive.
4) Cover any exposed electrical components with a plastic bag or plastic wrap. This will prevent the electrical components of the car from being exposed to water which will be needed.
5) Cover the breather or air intake and carburetor on older engines with heavy aluminum foil or plastic. You may choose to tape or tie this in place, since water can cause serious problems if allowed into this area.
6) Brush any loose dirt or debris from the engine surfaces, either using a stiff bristle paint brush, or a plastic bristle cleaning brush.
7) Mix a solution of "grease cutting" dish detergent and water, using about 2 cups detergent to one gallon water.
8) Brush your solution on the engine, working it into the dirtiest areas, wetting them thoroughly.
9) Get a garden hose. Thoroughly rinse the engine.
10) Consult the vehicle's service manual and look up material that will be needed to clean the engine block and other metal parts. For heavy grease, you may have to use a solvent like mineral spirits, but engine de-greaser, available at automotive supply stores would be better. A household de-greaser such as Simple Green may also be effective. Be sure to follow the instructions on the container.
11) Remove plastic after rinsing engine and cleaning away residue of whatever chemical that you used to clean the metal components.
12) Let the engine dry. Most engines with high energy ignitions will run with the plug wires (and distributor) wet, but may misfire or run "rough" until these components dry out completely.
13) Remove all the materials you used to cover electrical and fuel system components.
jdt
03-19-18 12:12 PM
Blueshark
ES - 5th Gen (2007-2012)
01-18-15 01:28 PM
LexBrett
12-03-14 05:20 PM
Zinda
04-27-14 08:32 AM
neomedic
01-10-12 10:12 PM
Quick Reply: Engine cleaning procedure
