Black paint looks like crap!?!
I have a 98 GS4. Black exterior and aside from having a magnet hidden somewhere inside my front bumper that attracts only stones and not metal, the overall paint condition is pretty bad.
The paint is fading and looks as though it was wrapped in packing tape that left marks on it, especially on the roof. To make things even worse, our two kittens/cats have scratched up pretty much every side of the car by attempting to jump up on it and sliding back down, claws out!
Short of just repainting the whole thing..... and/or boiling the cats....
What can be/should be done? Use a polishing compound on it? Is this something that you (me) can do yourself?
Is it true that the black paint doesn't have a clearcoat on it and it will never really hold up?
Thoughts!?
Thoughts!?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Black paints with no clearcoat usually have ample paint applied to make up for the lack of clearcoat. Automotive finishes will hold up well if protected by waxes or sealants.
If you don't have a garage, chances are a black car will be a chore, or an eyesore.
After washing:
Can you feel the marks on the roof with your fingertips?
or the cat scratches ?
Does the paint look etched?
Use a Mirepoix with the cat boil.
Carrots, celery, and onions
About an hour before serving, toss in 2 cups of diced potatoes. Yum.
After washing:
You should have clearcoat. But the cats in my neighborhood have a method of removal...clawing.
If you use polishing/rubbing compounds on a black car, you will have horrid swirl marks and fine scratches. If you have cats that you let outside, you should just go paint the car white. I would suggest offering your neighbors the same courtesy. Your cats are probably not just ruining your car.
If you want to try to restore your paint job, I would get someone to do a careful wet-sanding. Then apply about 10 coats of Zaino. De-claw those cats or leave them indoors. (sorry it is a sore spot with me)
The last black car I had, I stripped to metal, primered and then painted it with ultra hard jet black paint. Then anytime I got a ding, scratch, or damn cat claw in the paint....I just re-painted that panel. It always matched because it had no tint and no metallic.
Best of luck.
MW
Best of luck.
MW
for the really fine scratches, try something called 3m Swirl Mark Remover from some place online or Mequiar's Scratch-X from many locals stores. rub those into the scratch until the paste becomes a powder and at least some of the scratch will disappear. use a microfiber towel if possible or at least a 100% terry cotton towel. otherwise, cheap towels will swirl your car, as will cheap washing items/techniques
the "tape residue" on the bumper...can you feel it? or, is something stuck on there or are they also scratches? if you could feel it, like something is stuck on there, try a bug and tar remover if it is some crap like that. if its hard, like old dust or watermarks, get something called a clay bar. you should do this anyways, it'll make your paint feel like glass again. a claybar from autozone or walmart will take all this stuff that is stuck on your car that you can feel but not wash off. run your fingers across the paint if it doesn't feel like your windows, the claybar will make your car so much better, and it's $15 tops.
I'd be pretty surprised if you didn't have a clearcoat.
With the clay bar, be sure to do it _before_ waxing the car. You want to be cleaning the actual surface finish. You can get products that prep the surface (they strip the wax) without harming the finish. I think 3M makes some, but I can't remember the name.
I also used to have a black car. I don't know how bad your scratches are, but try a scratch removal product before you do a rubbing compound. Rubbing compounds work by gently abrading the finish down the depth of the scratch (I think).
One other thing you can try is filling in the deep scratches/nicks yourself with a matched paint touchup and clear coat product. You need a perfect paint code match for this, so try here for products and ideas on technique:
http://www.duplicolor.com/products/scratchfix.html
http://www.paintscratch.com/touch-up-paint-moreinfo.htm
I ordered some factory matched paint and some clearcoat from Paintscratch.com but never got a chance to use it as the car was totalled.![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Once the finish is "repaired", you can protect it with several coats of wax (NOT silicone - you'll never get it off).
Meguiar's in particular carries a large line of specialty products for just about any car care need, and their website is pretty helpful in discussing methods.
Ral
Ral
I appreciate everyones ideas, will definitely get some clay, and try some Scratch-X. Will let you know how it comes out.
Anybody want a couple of nice (big) kittens?
Originally posted by RalAegidius
Are they nice and meaty?![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
lexus black has no clearcoat for some damn reason. two reps at two different dealerships that i was dealing with both said that, and both said it makes the car look better. i'd like them to tell me that a few months after it goes off the lot
Ral
For real! :eek: That wacky...no clearcoat. I used to have a red Dodge with no clearcoat and after 10 years that thing looked like *****.
Ral
Ral
I used Griots #3 polish with an orbital machine. Took all swirls out. Then hand wax with Griot's "Best in Class" wax. You'll love your black car again.
I wrote this up some time ago. Search on Griot and you'll find it.
Murph
PS: Get a dog to take care of those felines
Murph
I think I'm going to have to get an orbital polisher too. The last time I waxed my car I was utterly wiped out when I was finished. Plus it's hard to apply a thin coat by hand and I had to work really hard to get it off.
Ral
Ral
Ral...What wax are you using?
I'm 180º in my thinking.
I find waxing my car by hand to be one of the easiest and most rewarding steps in car care. Easier than washing and drying. Polishing and glazing...That's the major PITA.
If you use the right product, the right applicator and right removal towelage, and follow the instructions, it's a snap.
So, what wax are you using?
