[Paint Oxidation?]
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I am not sure what this is. is this whats called paint oxidation? it doesn't feel rough or anything, feel just as smooth like the rest of it. its not peeling. not sure what happen, been told because of heat and cold change. anyone know how to take care of this? appreciate it fellas.
This is mostly on top of the car, expose more from the sun, hood, roof and part of trunk. Few people said, wax and claybar wont fix this. did a search here and my.is, something about vinegar, i dont think i want to try that. any suggestion?
if there a local professional detailer/shop in Duluth, GA 30096 area that can take care of this, let me know.
http://www.ehow.com/how_5238403_remo...ars-paint.html
Here you go... Good luck, sucks to see this on a car so new.
They will charge you probably $100 to sand and re-apply clear coat for the hood. Maybe a little more expensive for the roof.
I have kind of the same thing, my carbon fiber hood looks foggy, I have to get it sanded and re-clear coated too.
Oxidation can also be a problem for car owners, since the outermost layers of paint are constantly exposed to air and water. If the car's outer finish is not protected by a wax coating or polyurethane, the oxygen molecules in the air will eventually start interacting with the paint. As the oxygen burns up the free radicals contained in the paint, the finish becomes duller and duller. Restoration efforts may include removing several layers of affected paint and reapplying a new layer of protectant. This is why professional car detailers recommend at least one layer of wax or other protectant be used every time the car is washed.
The secret of preventing oxidation caused by oxygen is to provide a layer of protection between the exposed material and the air. This could mean a wax or polyurethane coating on a car, a layer of paint on metal objects or a quick spray of an anti-oxidant, like lemon juice, on exposed fruit. Destructive oxidation cannot occur if the oxygen cannot penetrate a surface to reach the free radicals it craves.
This is why stainless steel doesn't rust and ordinary steel does. The stainless steel has a thin coating of another metal which does not contain free radicals. Regular steel may be painted for protection against oxidation, but oxygen can still exploit any opening, no matter how small. This is why you may find a painted metal bicycle still damaged by rust.
Look at all the 80's cars, they had this oxidation pretty badly.
Only way is to sand and respray.
A way to prevent this is to wax your car more often, especially if you leave your car outside exposed to the weather. Or just get a white car, you won't notice it!!!
Could be clear coat failure but I'd like to see what happens if you hit a small spot with a cleaner wax on a foam pad. From the photo and what you describe I'm not 100% sure that it is normal cc failure. If you could take a close up before and after photo of a spot that you use a cleaner wax on. Place a penny on the paint to help the camera focus and try to take the photo in full sunlight. If your camera has a macro ability use it to get close and look for ridges or edges surrounding the areas of light and dark.
From the images it looks as if the clear coat and base coat are separating but that the CC is intact. This is unusual and I'd have to ask if you know the history of the car. Was it repainted? I need to see a better photo of the damage but it looks like the car was over polished at some time, leading to CC failure and was resprayed with clear without proper prep.
I'm betting that is the case. You might take it to a body shop and have a painter give you an estimate for repair. If the car isn't that old, a repair may be a good investment.
As I mentioned earlier, probably about $100 maybe less to sand and respray your hood.
Roof might be $100 also, maybe a little more because it is up high so it's kind of a pain to reach.
And they have to mask off your sunroof and windows/mouldings, doors etc, and blend it to match your paint so there are no seams.
If you ask me, I'd say just do the hood because it is probably more visible/noticeable than the roof...
And besides... No one is going to be looking at your roof.. My car is slammed and I am 6'2" and i never see my roof.
