Dashboard Scuffs on RX
The other day I was cleaning the inside of the windshield and run the towel I was using across the dash on my RX to remove dust. On one portion of the dash where I wiped it left a scuff/streak. The dash is black and the scuff/streak is a lighter color.
I have been trying to figure out what to use to remove it or make it way less noticable. I have tried a magic eraser but that did nothing. Any ideas?
1st. don't use that towel again.
2nd. magic ereaser may make the problem worse as it is abrasive. It does help in some cases. In this case, it sounds like you have a scuff, and product is going to have to be used to make it less noticable. Try some areospace 303 if your pillars are vinyl/plastic. If they are fuzzy- then try a little woolite solution.
reb
08-11-04 10:56 PM
