HELP headlight restoration....im a little chicken about sanding..
wats up people? i've been searching how to restore my headlight...i own an 07 lex IS and its going to be her 5 year bday this december. Im a little chicken using sand paper on my headlight, how do i know if enough sanding is done? which grit do i start? whats the first thing and last thing should i be doing? where do i get the coat ? and whats the best? wat kind? which do u prefer... should i do both? coz the driver side has getting more aged than the passenger one? please expert fellow cl member...help me out on this..my fiance's car needed a restoration too..i would like to do this on my spare time..HELP!!! thanx...
Available at stores such as WalMart, O'Reilly's, AutoZone, Advance Auto Parts or from a Club Lexus vendor, http://www.detailedimage.com/Meguiar...tion-Kit-P591/ the heavy duty headlight restoration kit has everything you need except a electric/battery drill to restore headlights.
Easy to use and plenty for two cars.
PS - you'll need some tape to mask off around the headlights, need to protect the paint during the process. The process is easy, quick and painless. Easily done in your spare time.
Since your car is not that old try using a less aggressive method first like one of those headlight cleaning kits/liquids or just a regular polish. If that does not make them look brand new then you will need to wetsand. If your headlights don't look too bad then you can start out with 1000 or even 1500 grit and then finish with 2000 grit. Once you are done with 2000 grit you will need to polish the lights with a compound/polish to get the sanding marks out. Go on youtube to look for the proper ways to wet sand as it will be difficult to explain fully. A Porter Cable will make the polishing much easier but you can do it by hand, 3M makes a good polish/compound. If you don't polish after 2000 grit your headlights are going to look opaque/foggy when they dry.
Going straight to sand paper is a no-no in my book (unless there are obvious signs that a polish or compound won't cut it) because once you've sanded them down, there's no going back. And do yourself and your arms and shoulders a favor and buy a buffer... it is such a joy to polish with a machine as opposed to fatiguing yourself doing it by hand. Plus with a machine you will reach results that are never attainable by hand.
coupey
02-14-12 05:45 PM
