Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Is there anything I can do about my windshield?
Old 11-23-11, 11:52 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Default Is there anything I can do about my windshield?
Before I go buy a new one, which would be a shame with a good solid windshield, is there anything I could do to fix this odd issue of unknown substance?
I've already rubbed it with goo-gone, alcohol, and waxed it. Not even a dent in the issue. No idea what it was. like oil splatter, road salt splatter, something........
Old 11-23-11, 12:06 PM
Luv2xl
Luv2xl's Avatar
could light grit wetsanding be used in this case?
Old 11-23-11, 12:15 PM
Teal Sc400
Teal Sc400's Avatar
I would use a razor blade with a drop of paint thinner, if you haven't tried this step/process.
Old 11-23-11, 12:16 PM
veritek
veritek's Avatar
I've heard you can get rid of water spots/acid rain spots on a windshield by wiping it with vinegar and newspaper (something about the combo that does it I think). I've never tried it, but maybe this would work on this mysterious stain you have?
Old 11-23-11, 12:17 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Forgot to mention the razor. Not much I haven't done!
Old 11-23-11, 12:30 PM
Teal Sc400
Teal Sc400's Avatar
more idea's: Mr. Clean magic eraser or Autoglym Glass Polish & Cleaner
https://www.clublexus.com/forums/aut...verything.html
Old 11-23-11, 12:40 PM
99SC42
99SC42's Avatar
The razor won''t do it.
Is it on the inside or outside?
looks like the inside.
Talk to windshield repair man , they have an electric buffer and it should buff out .
Worst case $185 for a new one.
Old 11-23-11, 12:58 PM
GR6RR
GR6RR's Avatar
Wet Sand the BISH with 1500-2000 grit paper... I have Wet sanded aquariums and the windows on my 2000 4Runner... It wont scratch the glass...
Old 11-23-11, 01:05 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
I've got a similar issue with my Saturn. I've got this weird crud on the windshield and I can't get it off. I may try the sandpaper.
Old 11-23-11, 01:10 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Went and bought brillo pads, no dice. Magic eraser, no dice.
Nothing is working Only clue to this is that it goes away when wet so has to be on the outside. The water masks the effects.
Might be new windshield time.
Old 11-23-11, 01:14 PM
97-SC300
97-SC300's Avatar
Try paint thinner? Prep Solvent? 3M General Adhesive Remover?
If you have a buffer, you can always try to see if a compound and polish will do anything.
Old 11-23-11, 01:16 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Already says waxed it in OP. I'm pretty much out of ideas.
Old 11-23-11, 01:33 PM
jfelbab
jfelbab's Avatar
Eastwood glass polishing kit. This is an amazing product that works on glass like a polish does on paint.
http://www.eastwood.com/glass-polish...ches-5658.html
Old 11-23-11, 02:00 PM
97-SC300
97-SC300's Avatar
I am not talking about waxing it OLT. Waxing is the last step. You put wax on something after it is perfectly clean and polished to protect your work.
The reason I suggested Prepsol, Thinner, or the 3M gen ad. rem. is because they are really powerful at removing stuff like tar, baked on grease or other substances that have really bonded with the surface. If a chemical can't remove it, then you can try a compound, which is abrasive to try and polish it out.
Waxing obviously won't do anything to that.
Old 11-23-11, 02:03 PM
embolism
embolism's Avatar
compound/polish is not the same as wax. They have abrasives that should take that stuff off.
If you have a buffer, try using M105 on a white pad
if you don't have a buffer, have you tried using detailing clay on it?
sounds like this guy is having the same issue you describe:
http://www.autogeekonline.net/forum/...ly-ruined.html
maybe there are some tips there that will help
Quick Reply: Is there anything I can do about my windshield?
