Door still cover scratches
I use PERL - http://www.autopia-carcare.com/perl-...e-coating.html
If you use a 1:1 dilution it does a great job on darkening the black plastics and rubbers. Does not make the scratches go away but they blend in better. Works great on tires as well.
Just wondering if you guys have any recommendations for the scratches on the plastic door sill covers from normal use?? There are scuff marks and light scratches from normal wear and tear.
Also, there are scuff marks and scratches on the door. Especially the cover for the speakers.
What do you guys do to try to get it cleaner looking? Thanks.
As for abbreviating calling me a dumbass, you can save that remark. I'm not the person recommending a clear plastic polish for door sills, nor would I stoop to that level. If you cannot accept being wrong, I suggest not posting inaccurate information or making suggestions that have absolutely no bearing on the problem the OP is asking about.
I would also suggest reviewing our forum rules prior to remarking like that again. We expect everyone to behave as adults.
Big Mack
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Guys knock off the name calling. If you can't post maturely and politely then don't push the
button.
![](http://images.ibsrv.net/ibsrv/res/src:www.clublexus.com/get/forums/images/buttons/reply.gif)
Apparently the PlastX I use does not realize that colored plastics are, well in fact plastic. I works just fine on any plastic. I have used it on plastic on a cell phone, the plastic woodgrain on the dash, and oh my the plastic on the interior of my trunk which is black. It is great at removing scratches and the results are not noticeable from the surrounding area.
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Plastx is not designed to work on ABS, which is what the door sills and speaker grilles are made of, and why I said what I said. Neither has a clear coat over them, so Plastx is not the optimum thing to use, IMO. Meguiars also does not recommend it for ABS components - but they could be wrong.
OP - pictures would go a long way. It may be something where you could very (very, very, VERY) carefully heat the plastic a bit to soften the scratches, but that's an extreme solution that shouldn't be a first resort. I've done it when it was the only option, but it can be tedious and again - you have to use extreme caution or you're going to warp the bejeezus out of the panel.
Big Mack
Oldsig
02-16-19 03:05 PM
b2884987
01-25-18 06:04 PM
Mcon
04-01-14 11:46 PM
