Removing scratches from windshield
I tried searching, didn't see anything very recent on this topic.
I somehow put a few VERY minor but irritating scratches in my windshield ('05 ES330) a few weeks ago when scraping off some ice after a storm. I'm not sure how this plastic scraper did this, I've used it in the past with no issues, but it's in the trash now. The worst scratch is right across the middle of the windshield, right dead center in my line of sight, so I can't ignore it. I can barely feel the scratch if I gently drag a fingernail across it.
What can I use to polish them out? I have a PC 7424 polisher.
Thanks.
Thanks.
If you can feel it with your nail, it might mean that it is a legit scratch, not just a scuff. If that is the case, I believe the thing used to remove it was called Cerium Oxide. However, it requires a lot of patience and proper skill to work it correctly. I'd recommend going to a glass polishing place to get it taken care of. This is assuming it is a legit scratch of course (in which any paint polish will have no effect on glass due to it being too hard)
Yep you need something with Cerium Oxide in it and probably some glass polishing pads for your PC. You can use a normal foam cutting pad but it heats up very quickly which can damage the glass (you can use a mist of water every now and then to cool it though)
I just bought Car Pro Ceriglass.. contains Cerium Oxide
That's probably the worst decision to make in this sort of situation. From what I have seen, a legit 9/10 glass repair companies or bodyshops don't have the slightest clue on how to PROPERLY remove and re-install a new windshield. 9/10 times, they will cut the paint on the edge to remove the glass and not lay down the proper primer material and in about a year you will have your whole roof rusting.
The best thing to do if you have a repairable front glass is to either polish it yourself with glass cutting pads and something like this:
http://www.autogeek.net/carpro-ceriglass-polish.html
OR to have a place polish your glass to remove any repairable defects. Replacing the windshield should always be a last resort.
Thanks.
Thanks.
Thanks.
Thanks.
quick questions, how good is this product for removing stains on the windshield. On the webpage it says it will remove it but I want to know from some one whos tried it as one of my car is suffering from this. It is so bad that I can see very well as i get shadows of stains after my wippers have cleaned off the morning dew.
