Best way to clean inside wheels?
I have the 07 IS250 with the factory clear coated silver rims. Include the rims over time has begun to collect baked on brake dust and dirt! I've tired using a wheel cleaner but it doesn't work.
Whats something else i can try? Simple Green? Steel Wool?
Any help would be appreciated!
Once a year I remove the wheels from the vehicle and do a thorough cleaning, polishing and sealing. I find this is a good time to inspect the tires and remove any embedded stones, look for cuts, and measure tread depth across each tire. If you are experiencing uneven tread wear you can have the suspension looked at before you ruin your of tires. If you do this, be sure to retighten the lugs using a torque wrench and take a spin and recheck the torque settings.
Once cleaned and sealed, the wheels are relatively easy to keep clean by using car wash soap and a wheel brush like this one:
This brush has a wire frame that is bendable so you can get behind the spokes. Using stronger wheel cleaners would compromise the sealant so I don't use them.
Former Sponsor
Good post!, or put the car on some ramps and clean it that way. That is one advantage of the CV3 wheel we sell, its such an open design you can clean the entire wheel from the outside.
I'd actually recommend the Wheel Woolies instead since they don't splatter at all unlike the one Jim posted. Here is my review on them:
Review: Cleaning Rims w/Wheel Woolies
Former Sponsor
here you go.
EZ detail brush
Sonax Full Effect Wheel Cleaner
It would be good to throw a good wheel sealant on them as well, this will reduce the cleaning time and protect the wheels.
EZ detail brush
Royale with cheese
I myself use the ez detail brush but according to eyezack's review, the wheel woolie is the brush to get for cleaning the inner barrels.
i also take the wheels off once a year for a thorough cleaning and coating with sealant on the inner barrels. there's less brake dust build up that way.
For the initial clean, I find it is easier to remove the wheels off the car to clean them properly. Use a good wheel cleaner like the Sonax extreme or P21S wheel gel as directed, and you'll have sparkling clean wheels very easily!
Use a sealant on them once clean, it gives them a non-stick effect to keep them cleaner, and make cleaning far more easier afterwards. I'm using a glass coating on mine, C.Quartz. I highly recommend!
After they have been coated/sealed, you just have to use car shampoo to clean them! The brake dust that manages to stick, comes off extremely easily!
Do not use steel wool! Don't use anything that will scratch them up!
I tried using a wheel cleaner, doesn't work? Any other ideas?
And I was thinking about a wax, but wax will just melt off after 5 minutes due to the heat in there..So can a synthetic wax be applied, like Meguires Ultimate Wax? Topped by rainx?
Durable wheel waxes/sealants to look at are any of the Collinites, FK1000P, and any of the coatings like C.Quartz and Opti-Coat 2.0. Coatings will last eons longer. Your megs ultimate wax will work, but don't put anything else over the top. IIRC it's a sealant.
Baked on brake dust can often be difficult to remove. The strongest wheel cleaner I've used is Meguiars Wheel Brightner Concentrate. It is made for professionals and is a bit hazardous. It needs to be used with gloves, goggles and adequate ventilation. It cuts through stubborn brake dust like a hot knife through butter.
here you go.
EZ detail brush
EZ detail brush
I would sure trust Phil on this one!!! I'm thinking he's cleaned his share of wheels and knows what works!
here you go.
EZ detail brush
EZ detail brush
