Couple of Quick Detailing Questions
I am going to detail my car with this method (posted in the sticky by a moderator)
My questions:
1) Should steps 1-5 be done once a year? Twice a year?
2) How often should the car be washed regularly? And what steps are included in a basic car wash? Just step 1?
3) How often should I use the quick detailer? In between the regular washes? How often would that be? And what's a good quick detailer?
Thanks for any advice! I have all of my products ready and can't wait to start work on it. How long do you think steps 1-5 will take?
If you just go with this five step process, I'm sure you will be pleased with the results.
1. Wash with a good car washing soap. (i.e.Meg's Gold Class or NXT Car Wash)
2. Clay the paint, glass and wheels. (Any brand clay kit and lubricant)
3. Clean with a paint cleaner. (Try Meg's Deep Crystal Paint Cleaner)
4. Polish with a pure polish or glaze. (Try Meg's Deep Crystal Polish)
5. Wax with your choice of carnauba wax or sealant.
Maintain with regular washing and quick detailer.
1) Most car sealants can last up to 6 months when taken care properly while carauba wax only last up to 2-3 months. Personally I like to polish the car once a year while waxing it 2-3 times per year. Make sure you wax it after claying and polishing, because after step 2-4, all the protection will be gone. But make sure to clay before waxing because you don't want the contaminants to bond into the paint.
2) If you have time, wash it weekly, but it you don't, try to do it bi-weekly. Normally a wash is just step 1. Make sure to use a two bucket system, proper washing soap (Optimum Car Wash is my favorite) and a grit guard if possible, if you want to take it to the next step, use a foam gun/cannon for pre-rinse to get most of the dirt off. Dry the car with a waffle weave drying towel. I personally like to use some spray wax after each wash to boost the existing wax, such as the Meguiars Ultimate Quik wax (you do not have to clay the car if you are using a spray wax).
3) Quick detailers are mostly used to clean off light dust from the car, I personally dont like using them because I feel like I'm putting swirl marks into the car, I only trust a properly washing. But if it's used properly under the right condition, they are great products and a great way to keep the car clean. Many car enthusiasts quick detail their car after every drive, but for me a weekly wash is good enough for me. I prefer the Meguiars Ultimate Quik Detailer.
If you use spray wax after each wash, do you have to remove this wax the next time you wash? (I use ONR to wash - hence the question).
People get into stripping their lsp before their full details which also puzzles me sometimes since all the other steps that follow i.e. claying, iron x, polishing, etc will surely strip their wax anyway...
Would you recommend Meguiars Ultimate Quik wax? Or is there another one that you'd recommend that would hopefully last a little longer than a couple of weeks? (I use Opti seal paint sealant every 8 months or so - just looking for something to use in between to give the deep shine - when I do the maintenance washes.)
I read about a bunch of products (dodo juice, Optimum's spray on wax etc) - so I'm thoroughly confused about which one to use!
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Spray on wax is certainly much easier to use, but I do have a PC, so can use the regular wax as well if needed.
Thanks ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I read about a bunch of products (dodo juice, Optimum's spray on wax etc) - so I'm thoroughly confused about which one to use!![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
It's rare to have incompatibility issues but it does happen sometimes...
Dysfunctional Veteran
LOL:
1. Wash (2 bucket)
2. Clay
3. Wash again
4. Polish (usually Megs 105, 205, or UC).
5. Glaze (Always Megs #7, havent found a better one for the money).
6. Carnuba Wax (usually Megs 26).
7. Seal (Stuck on Jetseal 109 for the last couple of years. Kind of expensive but I like it).
6, and 7 are reversible, some argue you want to put the wax over the sealant, I have found little/no difference in the shine/longevitiy, so I usually wax, then seal. Jetseal109 lasts up to a year, but I am **** and do it every 3-4 months.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Truth.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Waxfail. ![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
1. Wash (2 bucket)
2. Clay
3. Wash again
Truth.
Since you are using Opti-Seal, just get their Optimum Spray Wax. It is strong enough to be a stand alone lsp so the combo with OS under it will definitely last you a long time. It's good to stay in the same line as I was just reading about a problem someone is having with streaks on their optiseal when using a different branded quick detailer/spray wax...
LOL:
1. Wash (2 bucket)
2. Clay
3. Wash again
1. Wash (2 bucket)
2. Clay
3. Wash again
If the surface isnt properly prepared (remove all contaminants), it may clog up the polishing pads.
Here is a very detailed review comparing the ultimate Quik wax with 3 other popular spray waxes, which includes the optimum spray wax.
http://www.autogeekonline.net/forum/...-quik-wax.html
FWIW, I buy UQW in gallon jugs. It's known as D156 Synthetic Xpress Spray Wax in Meguiar's Detailer Line. I use it on the entire exterior of the vehicles I detail. This includes wheels, vinyl trim, rubber seals, chrome, stainless steel and glass.
There is a lot to like about this product.
• It doesn't streak
• It can be applied in direct sunlight
• It works on many types of surfaces, paint, vinyl (textured and smooth), chrome, stainless steel and glass
• It doesn't dry white or leave any dust
• It applies and removes in seconds
• It is inexpensive and easily obtained nearly anywhere
• It lasts for several weeks
• It leave the paint feeling very slick which means dirt and bugs don't stick to the paint
• It looks stunning
• It is a great 10 minute wax/sealant refresher after every wash
• It sheds water like RainX
This is just about my favorite Meguiar's product.
• It doesn't streak
• It looks stunning
