Meguiar's Products List
Meguiar's Mirror Glaze car care products can make your Lexus look great.
You'll find the name, description, model number and package size(s).
#00.....Hi-Tech Wash
Astute car collectors and highly particular professional detailers named this their product of choice for gentle washing action. Just a few precious drops of this detergent-free formula will guard your carefully prepared finish with the safest wash you can possibly find. Pros will find Hi-Tech Wash indispensable for serious restoration projects.
M-0016 ....................16 oz.
#1.....Medium-Cut Cleaner
For machine removal of tough surface defects. Buffered abrasives provide just the right degree of cleaning power for jobs that demand a solution between Mirror Glaze Fine-Cut and Heavy-Cut Cleaners. Medium-Cut Cleaner quickly removes swirls, water spots and water sanding marks. It also leaves the silicone-free surface essential for proper painting. For use with a rotary buffer only.
M-0116 ....................16 oz.
M-0164 ....................64 oz.
#2.....Fine-Cut Cleaner
For machine removal of stubborn paint defects, Professional detail shops rely on Mirror Glaze Fine-Cut Cleaner as the best answer for removing light oxidation, swirls, scratches and hard water spots. Its special formula of Buffered Abrasives turns into a gentle buffing rouge, giving you a professional finish that's ready for polishing, protecting-and if necessary, painting. For use with a rotary buffer only.
Made for Professionals.
M-0201 ....................1 gal.
M-0216 ....................16 oz.
#3.....Machine Glaze
The ultimate machine-applied shine. Meguiar's Machine Glaze lets you achieve a deep, rich gloss unmatched by any other polish, glaze, wax or sealant. Rich nutrients penetrate and revitalize all paint finishes, as well as fiberglass and plastic. Buffing residue wipes off easily to reveal the original brilliance and clarity of your finish. For use with a rotary buffer only.
Made For Professionals.
M-0316 ....................16 oz.
M-0364 ....................64 oz.
#4.....Heavy-Cut Cleaner
For machine removal of serious paint defects. Mirror Glaze Heavy-Cut Cleaner removes deep swirl marks, scratches and severe oxidation, as well as etching from alkaline or acid rain. With proper application techniques plus Diminishing Abrasive Action that provides protective lubrication, you'll restore a smooth surface-also suitable for painting-without scouring your finish. For use with a rotary buffer only.
M-0416 ....................16 oz.
#5.....New Car Glaze
Enhances even factory-fresh finishes. The specially formulated nutrients in Meguiar's New Car Glaze restore the deep, radiant shine that even brief environmental exposure can begin to strip from an automobile's finish. Safe and effective on fiberglass and plastic as well as paint, this distinctive product lets you create a beautiful gloss with very little effort. For use by hand, orbital buffer or dual action polisher.
M-0516 ....................16 oz.
#6.....Cleaner/Wax
A single step to brilliant protection. The right wax for many users is one that cleans, polishes and protects all in one simple step. Meguiar's Cleaner/Wax fills this need. Applied by hand or machine, it removes light oxidation and lays down an extremely durable high-gloss finish.
M-0616 ....................16 oz.
M-0664 ....................64 oz.
#7.....Show Car Glaze
Legendary on the show car circuit. For those of you who love a hand-rubbed finish, this superb glaze is guaranteed to give you that deep, wet shine prized among car collectors. This polish will outshine all other hand-applied polishes, glazes, waxes or sealants. It won't dry white, and it's safe and effective on all paint finishes. Used as part of your 5-Step Surface Care Cycle, Show Car Glaze is just one of many Secrets of the Pros that add up to a superlative appearance for your treasured automobile. For use by hand, orbital buffer or dual action polisher.
M-0716 ....................16 oz.
M-0764 ....................64 oz.
#9.....Swirl Remover
A cleaner and a polish in one bottle. If, much to your dismay, you notice swirl marks, tiny scratches or other mild defects, you'll appreciate our ultra-safe Swirl Remover. This amazing product will carefully eliminate those annoying problems-whether applied by hand, or using a machine buffer/polisher. While Swirl Remover is gently cleaning, it's also polishing, leaving a dramatic, high-gloss shine. It's even formulated to reduce splatter and make application and wipe-down easier. For use by hand, orbital buffer, dual action polisher or rotary buffer.
M-0901 ....................1 gal.
M-0916 ....................16 oz.
#10.....Mirror Glaze Clear Plastic Polish
The finishing touch for maximum clarity and brilliance. Meguiar’s Plastic Polish provides the second step in a two-step restoration process for clear plastics. One easy application protects surfaces previously cleaned with #17 Plastic Cleaner. You will reveal the materials natural brilliance, while leaving behind an anti-static coating that helps repel damaging dust and dirt.
M-1008 ....................8 oz.
#16.....Professional Paste Wax
* A special blend of exotic waxes
* Provides exceptionally durable, long-lasting protection to cleaned and polished paint
M-1611 ....................11 oz. (Paste)
#17.....Mirror Glaze Clear Plastic Cleaner
Safely removes hairline scratches, dirt and grime. Clear plastic that has lost its clarity due to significant contamination and fine scratches should be treated using a two-step process. Meguiar’s non-abrasive, alcohol-free Plastic Cleaner aggressively cleans and removes scratches without harming the surface. Follow up with #10 Plastic Polish for a perfect finish.
M-1708 ....................8 oz.
#18.....Mirror Glaze Clear Plastic Detailer
A single-step solution that keeps clear plastic surfaces pristine. Regain the original crystalline clarity of plastic in need of restoration, using this convenient all-in-one product specially formulated by Meguiar’s. Simply spray it on and wipe it dry. You will safely remove surface contamination and achieve dramatic results on everything from window panels and instrument lenses to eyeglasses, CDs and picture frames.
M-1808 ....................8 oz.
#20.....Polymer Sealant
Polymer based formulation provides extra-durable paint protection. A unique blend of polymers, resins, silicones and imported waxes provides exceptional durability. Polymer Sealant ensures superior results on every type of paint, including clear coat.
M-2016 ....................16 oz.
M-2064 ....................64 oz.
#23.....Odor Eliminator
Unlike most odor control products, this remarkable formula safely removes offensive odors and doesn't allow them to return again when the car interior heats up or gets wet. Other products either try to cover up the odor with a stronger fragrance that soon fades or they only provide temporary relief. Cars are a lot tougher area in which to control odors than homes. The space is compact, temperature extremes are common, high humidity conditions occur and moisture can be brought in due to rain or snow. Meguiar's Car Odor Eliminator is the proven way to instantly and safely remove strong odors such as smoke, sweaty workout gear, pet odor, food smells and more. And the compact 10-oz. bottle can be kept in the glove compartment to quickly deal with emergencies.
G-2310 ....................10 oz.
M-2301 ....................1 gal.
#26.....Hi-Tech Yellow Wax
Enhances the depth of your car's color. This unique professional-grade formulation blends premium yellow Carnauba wax with silicones, polymers and other specialty waxes It provides maximum high gloss protection while it actually deepens your paint color. No wonder Hi-Tech Yellow Wax is the professional's choice.
M-2601 ....................1 gal.
M-2611 ....................11 oz. (Paste)
M-2616 ....................16 oz.
#28.....All Metal Polish
Just a dab of this safe and gentle product will clean, shine and protect any type of metal including stainless steel, gold and silver. Tarnish, rust, oxidation and corrosion wipe away without scratching the surface.
M-2805 ....................5 oz.
#34.....Final Inspection
The secret behind the "show car" shine enthusiasts rave about! When your car needs to look its best, rely on one of the key Secrets of the Pros: use Final Inspection. Its special high-lubricity formula actually encapsulates dust particles and enhances deep luster-without using water. In just minutes, you'll have a shimmering gloss that will turn heads. Final Inspection is perfectly safe for all paint finishes.
M-3401 ....................1 gal.
M-3416 ....................16 oz.
#36.....Hi-Tech Wheel Cleaner
A sophisticated professional formulation for any type of wheel, this acid-free cleaner is pH-balanced, non-toxic and non-corrosive. Gentle foam loosens brake dust, grease and grime to give your wheels a streak-free luster.
M-3616 ....................16 oz.
#38.....Tire & Trim Dressing Gel
· Patented antiozinates system prevents tires from turning brown.
· Keeps rubber molding and plastic trim looking showroom new.
· Longer lasting than traditional protectants.
M-3832 ....................32 oz.
#39.....Heavy Duty Vinyl Cleaner
Even years of ground-in dirt and grime can’t keep your rubber and vinyl from looking great again. This extra-powerful cleaning formula also removes the wax residue that turns these surfaces chalky, revealing their dark, rich natural color.
M-3916 ....................16 oz.
#40.....Vinyl & Rubber Cleaner/Conditioner
Many other products simply coat vinyl and rubber with shiny silicones. Meguiar’s remarkable alternative gives you professional results by penetrating and cleaning, while conditioning and protecting against UV damage. All while leaving a rich matte finish.
M-4001 ....................1 gal.
M-4016 ....................16 oz.
#62.....Carwash Shampoo & Conditioner
* Ultra high foaming, non-streaking formula.
* Ph balanced.
* Free-rinsing conditioning agents and paint nutrients provide sparkling streak-free results.
* The ideal product to safely maintain any vehicle after its been waxed and detailed.
* Paintable! Safe for use in the paint shop.
M-6201 ....................1 gal.
#66.....Quick Detailer
* One-step cleaner/wax, specially formulated for high-production reconditioning.
* Aggressive cutting action.
* Quickly and safely removes oxidation and blemishes.
* Restores deep gloss and provides a durable wax finish
M-6601 ....................1 gal.
#80.....Speed Glaze
Enriches gloss and color with machine or hand application. No matter how you choose to apply it, Meguiar’s Speed Glaze is a shortcut that cleans, polishes and protects in one simple step. You will quickly remove light scratches, stains and environmental contaminants. Speed Glaze is safe and effective on any kind of paint finish, including clear coats. It ensures that a deep, beautiful shine is just minutes away.
M-8032 ....................32 oz.
#81.....Body Shop Professional Hand Polish
The gentlest way to achieve a perfectly smooth finish. A special blend of polishing oils will transform subtle surface defects into a uniform reflective sheen. Rich nutrients feed your finish to replace vital oils stripped away by oxidation. Dark paints in particular will respond with a shimmering depth of color and clarity. Our silicone-free formula also allows painting.
M-8132 ....................32 oz.
#82.....Body Shop Professional Swirl Free Polish
Eliminates light scratches as well as swirl marks. The next step up in aggressiveness from Meguiar's Hand Polish, Swirl Free Polish has the enhanced cutting power to tackle fine scratches, as well as more rapidly erase swirls. It's formulated to apply smoothly-and wipe off with ease. Use it to safely restore a glistening reflective shine to all types of paint, including clear coats.
M-8201 ....................1 gal.
M-8232 ....................32 oz.
#83.....Body Shop Professional Dual Action Cleaner/Polish
Moderate abrasive power removes light to medium contamination. A touch more aggressive than Meguiar's Swirl-Free Polish, our Dual Action Cleaner Polish effectively deals with more significant stains, swirls, blemishes and oxidation. Its safe, Buffered Abrasive cleaning action attacks defects while guarding your finish against scratches. Rich polishing oils ensure a memorable shine.
M-8301 ....................1 gal.
M-8332 ....................32 oz.
#84.....Compound Power Cleaner
* Aggressive abrasives boost cleaning power and efficiency.
* Specially formulated for FAST, safe cleaning.
* Quickly removes Meguiar's Unigrit 1200 grit sanding marks.
-Diminishing Abrasives cut quickly, then reduce to a polishing rouge.
-Buffered Abrasive action lubricates the finish to prevent scouring.
-Paintable! safe for use in the paint shop.
M-8432 ....................32 oz.
#85.....Diamond Cut Compound
* Super fast cutting, low-swirl compound
* The answer for high solids paint: cuts super fast with minimal swirls
* Successfully tested in high solids production shops
* Low-dusting, low-splatter formula
M-8532 ....................32 oz.
#96.....Medallion Premium Leather Cleaner
Your leather interior deserves the absolute best. Leather offers years of lasting beauty and it deserves the best care. Medallion Premium Leather Care gently cleans away grease and grime, restoring premium hides to their original suppleness. It won't change the leather's original color or texture, and leaves no greasy residue. Meguiar's special formula combines vital moisturizing oils and special soft waxes in a water-based, pH-balanced formula to provide long-lasting protection against cracking and staining. And it's great on other leather surfaces like briefcases, purses, shoes and furniture.
M-9616 ....................16 oz.
#97.....Medallion Premium Paint Cleaner
Introducing the finest way to prepare your car's paint by hand, orbital buffer or dual action polisher. The rich lubricating formula of Medallion Premium Paint Cleaner safely cleans away blemishes and oxidation, preparing both clear coat and non-clear coat finishes for Medallion Premium Paint Protection. Used after washing, simply apply a small amount to an applicator pad or a clean, all-cotton terry cloth towel, and gently work into your finish. With minimal effort you'll remove fine hairline scratches-even stubborn stains! For use by hand, orbital buffer or dual action polisher.
M-9716 ....................16 oz.
#98.....Medallion Premium Paint Protection
Hi-technology equals exceptional results. Medallion Premium Paint Protection will restore your finish-especially dark colors-to a deep, full-spectrum shine. The exclusive Meguiar's MiraBenz bonding system uses positively charged molecules to "lock" the finish to the surface, making it almost impervious to daily assaults. Its balanced blend of nutrients and conditioners combines with superior waxes to provide brilliant performance. If you value perfection, you'll love Medallion Premium Paint Protection. It provides the deepest gloss and the longest lasting protection in one step.
M-9816 ....................16 oz.
#6.....Cleaner/Wax
* Ph balanced.
#80.....Speed Glaze
1WILLY1
Automotive Care & Detailing
15
01-27-15 10:53 PM
rfx45
08-25-07 02:09 PM
