can this be removed by wet sanding?
![](http://i537.photobucket.com/albums/ff331/rule1223/scr.jpg)
how does this look to you guys? can this be removed by wet sanding? if so, what kind of sand paper should i use?
thanks in advance guys!
I would only wet-sand freshly painted or custom paint cars and strongly advise against wet-sanding OEM paint finishes as the paint is usually very thin, or wet-sanding any paint without first using a paint thickness gauge (PTG) to check the thickness of available clear coat
