Zaino z-cs clear
No damage if you do more than 3 or 4 of Z-CS per year.. ...and you probably already know that you can just apply more Z2 or 5 layers for example on top of Z-CS. I do that all the time, and then finish with Z-CS, repeating the process over and over.
Well, I'm a 100% Zaino kinda guy in terms of these products for the last 15+ years, so can't suggest the result of the combination or results in your case, except to say if you've read the Zaino site, it eludes to Z-CS working on top of other products. If you want to be sure, I suggest you contact Sal, the originator of Zaino products with the contact link on the Zaino site -- he has personally been very responsive the few times I've asked questions. For the most part, Zaino products feed and benefit from one another -- e.g. Even the Z7 wash, actually helps the bonding of any existing Z2 or 5, increasing the look and durability, and you can mix and match the polish combinations without restrictions inside the Zaino line.
BTW, duration of any product is going to depend on the elements you expose it to. I for one, don't believe the maximum duration or strength of any product, regardless of manufacturer.
