Headlight restoration
There is some oxidation on my headlight 2IS, what are some waxes or products that will remove it safely. I dont want to use the abrasive method with sandpaper. thanks
If you're not going to sand, you will need a good compound and a random orbital polisher with a coarse pad. You will get fair results out of this method. pits and yellow haze will still be there.
If you want to do it right, use the Sylvania Kit, you will get AMAZING results, like NEW headlights. I used it on my 06 2IS.
To keep them looking this good...keep wax and polish on them. I put Clear Bra on mine which will keep the pits and hazing from occurring.
Good luck!
Good luck!
The Meguiars ultimate compound turn my dull SC430 headlights to look brand new.
I use a DA polisher and 4inch pad on the headlights.
I did this about 3 years ago and to this day it still looks fresh. I do put a layer of wax once in a while to protect the headlights from going yellow.
Would a normal car sealant / wax do the job sealing them after restoration? Also I heard that paint sealants / waxes yellows the headlight overtime, would I be safe to use my paint sealant (Wolfgang Gloss Sealant) and Carauba Wax on my brand new headlights that has never been polished before? Thanks!
