what to use on SUV black plastic trims?
I use Meguiar's Ultimate Quik Wax. This is a synthetic sealant that doesn't run down the side of your car in the rain like many trim dressings. It can be used in direct sun and it doesn't dry white. It is a wipe-on/wipe-off sealant that lasts for two to three weeks. It leaves a pretty decent patina on the trim as well.
I was also a Black Wow guy for years, but switched to "Solution Finish Black Plastic & Vinyl Restorer ". It comes in an even smaller bottle, isn't cheap, but takes just a little bit of product to give a great look that lasts much longer than Black Wow (because it is not silicon based).
I use chemical guys G6 Hypercoat for plastic trims on exterior. Very durable and leaves the plastic trims very good looking without being shinny, and is dry to the touch. It also has UV protection. It can also be applied onto rubber trims and such.
1JZ Single SC400
Last option is to tape off and paint to your shinyness. I used the Krylon Fusion on many plastics that sit outside and still looks impressive. Some people hate this, but I have had good results with it. The best results is when sanded and drying between coats is the key. Prep work ! GL
1JZ Single SC400
