Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
View Poll Results: Which Finish Do You Prefer?
Wetter looking = Better looking
332
46.56%
High Gloss
113
15.85%
Semi-Gloss
119
16.69%
Low Gloss
52
7.29%
Satin
66
9.26%
Flat Black
15
2.10%
Natural rubber (No dressing)
16
2.24%
Voters: 713. You may not vote on this poll
Tire Dressings
Old 09-29-03, 03:48 PM
  #31
parula
parula's Avatar
Engin, I've been wondering about the same thing for the product I use now, Turtle Wax "Wet and Black", as after I use it I notice when I wipe the tire a lot of BLACK stuff comes off.
Old 09-30-03, 08:09 AM
  #32
engin_ear
Everything in Moderation
engin_ear's Avatar
Don't know what that would be - it's not likely to be oil, since oil causes a slow deterioration when in continuous contact with rubber. It may just be a thin layer of road grime that is being cleaned off. I get a similar thing when I use silicone.
Old 09-30-03, 03:38 PM
  #33
parula
parula's Avatar
I noticed the apparent soft rubber surface after applying each of the tire dressings I used over the years.
My LEXUS manual says on page 58, .. "DON'T APPLY SIDEWALL DRESSINGS/CLEANERS ......Instruct service personnel never to apply any other materials to enhance sidewall appearance. These may degrade the rubber and remove inherent ozone resistance." I think I got the quote right, check it for yourselves too in your own manuals.
Some of the Lexus dealers I have used apply these dressings, so I don't know what to think at this point, which dressings are OK?
Old 10-01-03, 07:19 AM
  #34
engin_ear
engin_ear's Avatar
Ozone also degrades rubber, by the way.
Old 10-04-03, 08:27 AM
  #35
parula
parula's Avatar
My stuff washed off recently and I notice that scraping a fingernail on the now dry rubber doesn't get much rubber if any now, when they were wet with the Turtle Wax spray-on I could get what seemed like a good bit of rubber off with a rag or fingernail. I hope these coating manufacturers have looked into this issue, I am concerned about damaging my tires but can't find much about it.
some more information here from a quick search :
http://www.autopia-carcare.com/tiwhcl.html
http://www.autoint.com/ford_leather.htm which has, "The use of a waterborne polymer siloxane or amino functional dressing is the only way possible to protect components of the tire was well as get "the wet tire look". Once this type of dressing is dry, it will repel water be resistant to detergents and don't attract dust."
I am going to try to find this stuff, sounds good!
Goodyear mentions not using alcohol or petroleum-based cleaners at : http://www.goodyear.com/rv/tirecare/age.html
Old 10-13-03, 03:22 PM
  #36
parula
parula's Avatar
Got and applied Meguiar's Endurance - High Gloss today.
I also bought some convex tire applicators that worked great, done in 10 minutes. Awesome look so far, we'll see how long it lasts. No spin off from a rather light application and driving <35mph.
Looks great but the smell is better!
Old 10-14-03, 08:30 AM
  #37
engin_ear
engin_ear's Avatar
Grape is good.
Old 10-14-03, 03:18 PM
  #38
parula
parula's Avatar
more like black cherry to me, might have to reapply to recapture the fragrance.
the whole garage smells of it
Old 10-15-03, 01:42 AM
  #39
Deanski
Deanski's Avatar
Default Dressing
Try 303 on your tires! Nice matte shine to it.
Regards,
Deanski
Old 10-15-03, 04:35 PM
  #40
parula
parula's Avatar
I'm not sure about these tire treatments, especially in view of my Lexus manual recommendation not to use them. I wiped the tire tonight over an area about 5-7 sq. in. and the wipe was really black and it's only been on a couple days, I wonder if this is really ok for tires?
Old 10-16-03, 07:49 AM
  #41
engin_ear
engin_ear's Avatar
It's generally not as bad as you think. The dressings are OK, even if they're removing a bit of the rubber, and that's questionable anyway. Usually the tires will wear out before any of this becomes a factor, unless you're using motor oil (arrrrggghh!). I've been using various tire dressings for many years, never had a problem with any tires. Keeping them clean and potentially UV protected is a good thing (I question how well some of these UV protectants work....)
Old 10-16-03, 04:13 PM
  #42
parula
parula's Avatar
EE, I hope you're right, it takes me 6 years or so to wear out a tire at ~10k a year so I am concerned the dressing technology is appropriate for the application.
tks!
Old 10-18-03, 04:14 PM
  #43
parula
parula's Avatar
Had some minor spin off apparently with the Meguirs gel, need to wipe it all off, it seems like it might permanently stain paint,
Looks good on the tires even after wiping down more, might have to wipe it more.
Old 10-20-03, 02:03 PM
  #44
Threxx
Threxx's Avatar
303 is the only way to go for any type of vinyl/rubber dressing including tires. It may not be the shiniest or the longest-lasting. But at least it protects your tires rather than feeding them the silicone that most other cheap dressings do (which will cause your tires to crack/fade/turn brown over time and will sling up on your paint.
The only other tire dressing I've found that I like is Meguirs Endurance (NOT the high gloss kind), it doesn't contain any silicones either and it actually lasts quite a while.
Again, if you want ultra-shiny tires but you don't want to use anything bad for them, you're out of luck. But if you just want them to look nice and black like brand new and not like a glazed donut, and you want them (and all the other vinyl and rubber on your car) to be protected, 303 Aerospace Protectant is where it's at.
Old 10-20-03, 04:04 PM
  #45
parula
parula's Avatar
Threxx. 303 sounds good, have to try it and use less Meg. Endurance at least by just a very light wipe on of the high gloss I got thinking it will last and I will only need little, just left too much on and these ribs on the Integity grab the stuff.
Quick Reply: Tire Dressings
