leathers seats soft and clean help
Well i want to know what everyone uses to keep their seats soft and clean my sc ould use a little bit of this treatment is lexol good?
I use lexol once every month or 2. It does make the seats cleaner but definitely not softer (at least in my experience). I just tried out leatherique this last weekend and I think that it is the only product that's going to clean the seats deep down and make them softer (by moisturizing the seats). It comes with the rejuvonile oil and Prestine clean, what makes this different from others is that you put the conditioner on first then the cleaner. How this works is the rejuvonile oil gets to sit on the leather for hours in baking hot sun, and it penetrates the seats and moisturizes the leather, while it does that it also pushes out all the dirt and grime that normal cleaner can't reach. Then you use Prestine clean which removes the extra oil residue and all the dirt off of the leather. When I did my car the bucket of water turned completely black with just one seat (I do weekly wiped owns and monthly maintenance with lexol). The results were amazing also, it removed many wrinkles and gave the seats a nice matte, soft finish that new leather seats has. It's a product that you have to try to really appreciate the affectiveness.
I have no connection with leatherique whatsoever. I'm just one of their 1000s of satisfied customer. But I mean it, if you want something that actually works, use leatherique...
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
leatherique system of Oil rejuvinator and pristine clean work. Specially if you let the car sit out on the sun with windows close. I also used a steam cleaner after the pristine clean to help with the removal of the pristine clean and it worked I do not recommend lexol it damage my leather on the gs400, started using it and in 4 month I started noticing small rips and color fade on my gs.
