How do I get rid of scratches on the interior trim?
I got this nasty scratch from installing my LED mirrors couple years ago. It has been bugging me the whole time and I can't figure out how to remove this successfully. Any ideas?
Someone suggested sharpie but it obviously don't match at all.
You need to replace that trim piece.
no, plastic can't be buffed like paint unfortunately.
It's the reason I keep my passenger seat all the way back even though my wife is only 5'2
I do this because of Newton's fourth law: the height of the woman is inversely proportional to the size of the bag she carries...
Late reply meant for new readers......try a black crayon on the hard plastic to fill the scratches, then wipe any excess off with clean dry cloth. Result is about 90% better then leaving it as it. It is basically wax so should not harm anything. I did it on my 08 is350 and am pleased with the results. My wife thinks it looks better as well. We are both **** about our car so the bar was set pretty high.
Honestly i'd just replace the trim piece though it will definitely make you feel a lot better in the end knowing that it's permanently fixed.
Thanks
I have been able to remove scratches with a Dremel and the dremel polishing kit. I use the small plastic brush at medium speed. I then use rubbing compound on the small buffing tool again at medium speed. I follow up with hand compounding using a foam applicator pad in the general area. If done really good you won't see anything. You may need to follow up with a polish or mild dye if the trim is slightly lighter in the area repaired.
This does take practice, so start off by practicing on somebody else's car.
You'd be surprised at how well this works.
anesthesia
10-03-16 04:19 AM
chromedome
Automotive Care & Detailing
05-18-16 10:24 AM
