Removing tar from polished stainless exhaust?
What would be the best way to remove little pieces of tar off of polished stainless mufflers and tubes? This is a joeZ exhaust I just picked up second hand. I would like to clean it up before installing.
Thanks 2gkaizen for your input
(update)
Just finished clean up. Using the bug and tar remover and followed up with metal polish.
The bling has returned.
(update)
If you can't get the tar off after the above methods, you can wet sand the exhaust with some high grit (less abrasive) automotive sandpaper.
You can follow up with a nice metal polish afterwards.
I've done it on exhausts before.
If you have scratches you can use emory cloth followed up by increasing higher grit sandpaper followed up with a nice metal polish.
SwiftLex7
05-14-19 11:46 PM
heidihidin
Automotive Care & Detailing
04-08-18 07:42 AM
jnguyen87
03-06-11 07:23 PM
