Last edit by: IB Advertising
Browse all: Cleaning and Detailing Guides
- How to Remove Swirls in Black Paint
Step by step instructions for do-it-yourself repairs
Best Product for Removing Swirls in Black Paint
#32
Here is an amazing bundle from Detailer's Domain:
The kit includes:
1 Griots Garage 6 inch Random Orbital Polisher
1 Uber 5 inch vented backing plate
1 Uber 5.5 inch Yellow Cutting Pad (Great for removing heavy defects with a cutting compound)
1 Uber 5.5 inch Orange Medium Cut Pad (Great for moderate defects with either a compound or polish)
1 Uber 5.5 inch Green Polish Pad (Great for 1 step corrections and general polishing to remove basic swirls)
1 Uber 5.5 inch Blue Finishing Pad (Perfect for finish polishing and/or applying wax or sealant)
1 Uber 5.5 inch Black Wax/Sealant Pad (Great for applying wax and/or sealant)
1 Menzerna FG400 Pint (Fast Gloss 400) (an amazing compound that cuts well and finishes down extremely well. It is easy to work with and simple to remove)
1 Menzerna SF4000 Pint (Super Finish PO106FA) (A fantastic finishing polish that will be able to remove any haze left over after compounding)
1 Menzerna Power Lock Sealant Pint (Amazing protection! Looks great too!)
6 Uber Ultra Microfiber Towels 16x16 (A must have! High quality MF towels are one of the most valuable tools you can spend your money on!)
^I would highly recommend ALL of these products to any one looking to enhance their cars finish... beginner or professional, these are some of the best products around. Period. And this is an amazing price for so much stuff!
The kit includes:
#37
The microfiber pad I found got hotter quicker than the foam pads and tended to have a bit more of a recoil. I need to use them more but they worked very well. The FG400 has a pretty good working time and for sure started flashing faster with the microfiber pads.
First picture is just after polishing and whipping down with 50/50 water/ISO second is after
Second is 18 hours after it was applied.
Just cell phone pics. it took me like 10 tries to get a beading picture cause it just wanted to roll off
#38
I've found FG400 to have an almost infinite working time... it may be that you were using too much product on the pad. MF pads don't require as much priming as foam pads because they don't soak up the product like a foam one might.
MF pads do get warm, and this often causes delamination. I would suggest switching pads after each panel to give them time to cool... I typically use 2 MF pads per car, cleaning them after each section and switching to the other pad after each panel.
Nice pics!
Nice pics!
#39
Nice pics!
Nice pics!
#41
Once I get my DA I'm gonna try getting rid of the swirls in my obsidian is 350 ill let you know how the CG products work out !
#43
I'm having a problem idk if you guys could help me out when I go to buff off the product using a quality microfiber it leaves a residue looking scratch the I'm able to remove by rubbing with my finger any ideas what's causing this and how to prevent this?
#44
A QD should remove this film. I'd suggest when next sealing the paint, try using less product and do a swipe test with your finger to make sure the product is fully hazed and doesn't smear before removing the excess. Use of several plush mf towels to remove the product might be helpful as well.
