hi all members, my seatbelts got dirty as noticed, plesse advise !
I didnt realize my IS seatbeltS got that dirty, also my driver side upper interior got dirty marks as shown below,any solution for me to clean them up, thank guys !
![](http://i1161.photobucket.com/albums/q509/huycyber/20130323_175023_zpsf9c2e4d1.jpg)
![](http://i1161.photobucket.com/albums/q509/huycyber/20130323_175033_zpsaa413577.jpg)
![](http://i1161.photobucket.com/albums/q509/huycyber/20130323_175109_zps5b770013.jpg)
Lukewarm microfiber cloth (make sure it's clean). You can also use a cotton towelette but it will be a little more abrasive. A Mr. Clean Magic Eraser can do some of the harder work but I wouldn't recommend it on leather. Just the belts and at the most the headliner.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
ok imma try your advice first ,its easy at no cost .
For the seat belt, the best thing is to pull it out as far as it goes, gently shut the door on it to stop it retracting, pass a rope through the hole in the buckle and get someone to hold it out taut, then pressure wash it. Leave it to dry thoroughly before allowing it to retract; you can spray silicone spray on it to make it retract much more smoothly, but again let that dry thoroughly before using the seat belt, to stop it getting on your clothes.
I recently took out a massive coffee stain from my cashmere-colored seatbelt using Scotchgard Oxy Carpet & Fabric Spot & Stain Remover.
http://www.scotchgard.com/wps/portal...glR4TBH6X1HDbl
Easy to use, and completely removed the stain. I would try that if you haven't. I found it at Walmart, in the househole cleaning section.
