Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
bird dropping on hood - mess and scratches!
Old 04-24-13, 09:11 PM
NYlexus
NYlexus's Avatar
Question bird dropping on hood - mess and scratches!
Long story short....
Saw few days old bird droppings on the car, without even thinking about it, I wetted a soft cloth towel and tried to scrape off the hardened dropping. BAD Idea!....
Not only I see a quarter size leftover mark but several scratches in an area of 5" diameter...
Right above the headlight on the hood and looks horrible. Can't get rid of the scratches....
What to do...help?
Sorry, but this is for my Bimmer...
2013 535i M CBM
Old 04-24-13, 10:31 PM
sydtoosic
sydtoosic's Avatar
never ever leave bird bombs on your paint... sounds like polishing is in order. the bomb etchings may or may not come out. that **** **** up your paint.
Old 04-25-13, 05:38 AM
jfelbab
jfelbab's Avatar
You might run to Walmart and pick up some Meguiar's Scratch Remover or Ultimate Compound and a couple applicators, foam and micro-fiber.
Use as directed and expect to need several passes. You may or may not be able to remove all the marring but it should look much better. Rub firmly, evenly and vigorously to remove the scratches. Don't use too much product and change the pad if it gets too wet.
Or, since this is a new car I'd probably suggest taking it to a local detailer who has a machine polisher and let him correct the damage.
If this is a common occurrence where you live and park you might want to keep a bottle of quick detailer and a few microfiber towels in the car. Remove bird droppings promptly to avoid damage and etching of the paint.
Old 05-06-13, 02:40 PM
Prochamber
Prochamber's Avatar
What to do...help?
2013 535i M CBM
In the future, always soak the bird droppings with water and let it set so it will soften up before you try and wipe it off the paint. Take care!
heidihidin
03-30-18 06:42 PM
oldskewel
01-20-11 10:45 AM
TEXAS83
11-24-07 11:48 AM
retrodrive
02-19-03 05:03 PM
pot_head
08-08-02 11:13 AM
Quick Reply: bird dropping on hood - mess and scratches!
