After OOC wash
After OOC wash
i've been using ONR & ONRWW religiously since the car was opti - coated (a couple of days after i bought her). today i used OOC and i must say it is a much better wash than ONRWW. ONRWW is amazing but the OOC is better, the paint is glossier and smoother. waiting for the OCW to arrive so i can top the OOC after a wash.
http://www.flickr.com/photos/76804690@N05/8752784518/http://www.flickr.com/photos/76804690@N05/8752784518/ by http://www.flickr.com/people/76804690@N05/, on Flickr
http://www.flickr.com/photos/76804690@N05/8752785602/http://www.flickr.com/photos/76804690@N05/8752785602/ by http://www.flickr.com/people/76804690@N05/, on Flickr
this is the beading properties of the ONRWW
http://www.flickr.com/photos/76804690@N05/8726073535/http://www.flickr.com/photos/76804690@N05/8726073535/ by http://www.flickr.com/people/76804690@N05/, on Flickr
http://www.flickr.com/photos/76804690@N05/8726072845/http://www.flickr.com/photos/76804690@N05/8726072845/ by http://www.flickr.com/people/76804690@N05/, on Flickr
Thanx...
OOC = optimum Opti-clean. I think I have found a product that I'll use exclusively. The only other product I use is Sonax Polymer Net Shield and Sonax Brilliant shine Detailer... The rest are Optimum... Oh, and Eagle One for my wheels and tires.
I've never used the OOC as a wash. I dilute it and use it as a QD/heavy QD and it works great. Its a very versatile product.
Are you using the OOC as you would ONR or using it in a spray application like I am?
hey SW what's happenin captain. I actually do it both ways, but I use the diluted OOC in a spray bottle to pre soak the panel before I wash with the diluted OOC from the wash bucket. Can't wait for the OCW to arrive so I can slap some wax on her. I have no wax on the car. I do have a coat of SNS on her that I applied about a month ago and it's holding up quite well. I've been using the Sonax Brilliant Shine Detailer. But now that I ordered the OCW...
Well, OOC is not a rinseless wash. It's not a shampoo either. It's their APC.
So you'd have to rinse the car afterwards if you truly want to remove any of its remnants. Also, using that as your go-to wash is kind of pointless. If the car is opti-coated, you don't need such a harsh chemical (not to say it's not safe) to do a typical maintenance wash. ONR or any regular soap will do a fine job at keeping the car clean.
The only time I ever use APC in a wash is if I am about to clay the car and re-polish it or put new wax on it; or if it has bird **** or other stuck on crap, and the APC is basically used as a pre-soak before the wash. Using OOC will definitely reduce the durability of any sealant or wax, not sure how it will effect OC since it's in a different category.
Optimum Opti-Clean is the most advanced waterless wash in the marketplace. It is designed to wipe away dirt and grime from automotive paint and other surfaces safely and effectively in a spray and wipe application. Optimum Opti-Clean contains the same proven polymer system that is used in the Optimum No Rinse Wash & Shine as well as additional polymers that add greater lubricity and protection to the paint. Simply spray Optimum Opti-Clean on any surface and wipe off with a plush microfiber towel till the area is clean and dry.
Having both OOC and ONR it never really occurred to me to use OOC like ONR, to me its a spray and wipe type product. I'd be interested to get Optimum's thoughts on using it diluted in a bucket.
I'm doing some digging around, and Optimum definately does not intend for OOC to be used in a bucket as ONR is used. See the below post from Chris @ Optimum on the AutoGeek forum:
http://www.autogeekonline.net/forum/...tml#post476612
I would recommend saving OOC to use in a spray bottle as a waterless wash/heavy QD and sticking to the ONRWW as my primary wash.
If you mean that ONR is recommended for dirtier cars...that is correct. Although Opti Clean is a higher concentration, it is intended as a waterless wash or a spray n wipe cleaner and a rinseless (ONR) can be used on anything except cakes on dirt.
Glad I could help!
I was thinking the samething about OOC. How do you wash your car with OOC since its supposed to be diluted with 3 parts water. You would be using a lot of it if you are using it in the same sense as ONR. I have ONR and OOC, I usually just use OOC as a qd. It's pretty strong of a product too. I also used to use OOC as a presoak wash for when my car is heavily soiled before using ONR, but after discovering auto finesse citrus lifes been a lot easier.
i do what i can Mo... , you know how we do...
good thing i only washed her once with the OOC. you live and you learn. Auto Finesse has great products.
