Official "Look What I Got Today" Detailing Thread
#121
Auto Detailing Master
Just picked up a new Mini Rupes LHR75e!
... as well as more Carpro HydrO2, Meguiar's M101, Lake Country Pads, and the new Rupes Microfiber Cutting pads.
Hoping this brings some warm weather so I can get back into detailing full speed ahead!
#122
Time to throw out pretty much all of the old stuff, and get new. The new items came today… The only bummer is that some items froze in shipping. I hope nothing was ruined.
#123
#124
#126
It says right on the bottle... if you want to use it in a foam lance, you use the product straight up... ie connect the foam lance nozzle directly to the bottle OR poor the entire bottle into the foam lance. The soap is not mean to be a heavy decontamination tool like IronX, however it should remove very minor iron contaminates with regular maintenance washing from what I understand.
Let us know your thoughts!
#128
can't go wrong with Optimum... that power clean is some good stuff, never used the OPS. the Iron X soap was cool, i like it for what it is, except for that God awful smell. i would def use it again, if my car needs it, i didn't get any runny red liquid, i was a little disappointed that the soap didn't produce any... my car is too damn clean, even the wheels. used some SFE after a month and no red runny liquid from the wheels.
#129
#130
Was that the premade kit or you pieced everything together? I have looked on DI and autogeek trying to see if i want to do a kit or not
#131
Iron X snow soap and CG Mr. Pink are not the same. Mr. Pink is reg maint. wash car soap. Iron X is used to decontaminate your paint so to speak. it dissolves the iron particles that adhere to your paint, due to everyday driving, fall out etc. works good on your wheels also. however, it does get your car nice and squeaky clean.
#132
And a little foam for good measure:
Super shiny!
#133
Ahh i see so should i buy both and use iron x or any kind of decontaminating soap only when doing a full detail and use mr.pink for washes after full detail? Trying to piece together my arsenal
#134
IXSS is a good shampoo to use for maintenance if your car has been coated, otherwise it will degrade or strip traditional LSP. It can, however, be used as a first step in the decontamination process.
Originally Posted by CarPro-US
Snow Soap has now become the first step in total paint decontamination.
CarPro’s Soap Gel has under gone some major changes! It is now known as CarPro Snow Soap and can be used with multiple wash methods, including as a snow foam, or as it was previously used, applied directly to your mitt. After a vehicle has been properly de-contaminated IXSS will keep it free of iron particles far more than any other car wash. If the vehicle has been previously coated with Cquartz or CQuartz UK, Snow Soap is a perfect match for maintenance. Clean your car and remove iron particles at the same time! Iron X Snow Soap has been adapted to be used as a dedicated Snow Foam or as a direct to mitt wash, while maintaining its fallout removal abilities.
Features:
-pH Neutral
-High Lubricity
-Uses only the highest quality cleaning agents & emulsifiers to wash your vehicles surfaces.
-Snow Soap cuts through grime & traffic film with ease.
-Excellent wheel cleaner - Agitate the gel directly on the surface of the wheel
-Cleanses the bodywork softly with rich foam
-Smooths the surface
-Use on paint, glass, wheels, headlights, plastic trim, clear bras
-Excellent on wheels (Apply gel directly to wheel and agitate the surface)
Dilutions:
-Up to 1:8 - Good iron remover but use regular IX on a "first time car". Above 1:8 it becomes a very weak iron remover, but still a great cleansing shampoo.
-Per car it will consume 400ml neat with foam lancer with a fully closed lancer valve. That dilustion is for working on iron. As you know a power washer with the foam lancer sprays lots of water which means a high dilution while spraying. This is why why we recommend it neat with foam lancer if you want the IXSS to react on iron.
-If you want simple snow foaming and car wash 3 to 4 oz works well.
Directions as Snow Foam:
Rinse your car well using power wash to remove dust & contaminants.
Add Soap Gel to warm water and shake well to mix within the snow foam lance.
Set your lance to give the desired effect and foam concentration you require.
Snow foam your car as normal and allow to dwell.
Dependant on the concentrations of the foam on the cars surface. You may notice a color change taking place when the foam is in contact with heavy fallout.
Rinse well, prior to moving on to your hand wash process.
Directions as Hand Wash:
Thoroughly rinse the surface to remove all large and/or loose particles.
Apply Soap directly to mitt or sponge and wash a section before rinsing the mitt/sponge and repeating with the next section. (While Snow Soap is used as a hand wash. It should not be added to your wash bucket)
You will notice the soap gel changing color where it encounters iron. This indicates fallout removal and highlights the areas of concern where you may wish to follow up with either Iron X paste or liquid, later on in the decontamination process. While small iron particals will be removed by IXSS larger particles or vehicles that have not been thoroughly decontaminated previously will require the higher concentrated Iron X or Iron X Paste.
Thoroughly rinse all surfaces
Notes:
-IronX Snow Soap will affect oil base waxes by approximately 50%.
-Do not use as a mainenance wash unless you are decontaminating your vehicle or it has been protected with a durable sealant or a coating (such as Cquartz, or CQuartz UK).
-Avoid using on fabric convertible tops.
Features:
-pH Neutral
-High Lubricity
Dilutions:
Notes:
#135
i can use the IXSS because my car is cited with OC 2.0., if your car isn't coated you'll just strip any LSP that you applied previously. CG Mr. Pink is cool for a maintenance wash, i personally became addicted to OCWC. IX concentration is much stronger than the IXSS, IXSS can be used as a first step... then follow with IX, but if you don't plan on stripping your LSP, then don't use the IX or IXSS as a reg maint. wash, however i was impressed with the lubricity of the IXSS, and the suds were pretty good also.
