Sticky dash
Oozing??? Oozing what ? Try some optimum power clean or any APC dilutio... Spray on MF rag and wipe, then get a dry MF rag and wipe down. Then wait a 5 or 10 minutes and wipe it down with an interior cleaner. CG inner Clean, diluted Opti Clean etc...
If this is just a build-up of cheap dressing, you should be able to clean it with an APC or dedicated heavy duty vinyl cleaner. Don't scrub with a microfiber as you may cause it to become shiny. Let the chemical do the cleaning and wipe up with white cotton toweling. If the towel is still showing grime when you remove the cleaner repeat the cleaning until the towel comes up clean. Remember that the dash is painted vinyl and that paint is quite thin. Use too much abrasion and the paint will be removed.
Once clean, I'd suggest a thin application of a water-based dressing. Choose a dressing that does not add any gloss to avoid glare.
This is most likely the sticky dash issue that some of us encounter.. its not a issue of bad products, or anything you can clean off. Its a deterioration of the material they used. Nothing short of a new dash will fix it.
If the dash material is getting greasy and oozing vinyl oils, it probably is caused by the sun and high heat. If the cleaning process doesn't remove this oily substance there is always this: http://www.coverking.com/custom_dash_covers.
My best guess of what this is, if not dressing build-up:
The dash must be made so as to not crack with temperature swings ranging from -40F to over 150F. Thats a lot of expansion and contraction that must be built in to the material to prevent cracking. The vinyl material may have lubricants embedded to accommodate this and it could be these lubricants expressing to the surface under high heat.
I'd suggest using a sunshade or parking in a covered area where possible as the temperature inside a car can easily exceed 150 degrees, even with the windows cracked, when parked in the hot summer sun.
My '11 es350 dashboard is apparently leather. No problems yet, just my 2 cents!
Over on the 2007-2012 forum there have been periodic reports of sticky dash. I don't recall seeing a fix for it short of some of the suggestions mentioned above.
No leather dash on the 2007-2012 ES350. Just a (nice IMO) vinyl product.
Memout
Automotive Care & Detailing
14
06-05-08 02:24 PM
