Novus plastic cleaner alternatives question
I've used Novus #3,#2,#1 and Plexus as my headlight cleaner.
I like Novus and I think it worked great. I wanna try new product but do you guys recommend any product? maybe 3M or Meguiar etc..
Meguiar's offers a 2-step process. I've had great luck
using only Meg's #10 without #17. See below.
These products are available at many auto stores and marine stores.
Meguiar's #17 Mirror Glaze Clear Plastic Cleaner
Safely removes hairline scratches, dirt and grime. Clear plastic that has lost its clarity due to significant contamination and fine scratches should be treated using our two-step process. Meguiar’s non-abrasive, alcohol-free Plastic Cleaner aggressively cleans and removes scratches without harming the surface. Follow up Meguiar's #10 Plastic Polish for a perfect finish.
Meguiar's #10 Mirror Glaze Clear Plastic Polish
The finishing touch for maximum clarity and brilliance. Meguiar’s Plastic Polish provides the second step in our two-step restoration process for clear plastics. One easy application protects surfaces previously cleaned with #17 Plastic Cleaner. You will reveal the materials natural brilliance, while leaving behind an anti-static coating that helps repel damaging dust and dirt.
LEXBERG, what lexus do you have?
I'm not sure if you bought the light bulbs or plastic cover but can you tell outside or inside is dirty? I suggest you should clean up outside cover with wetsanding (#2000 grids with soap water) and use those scratch remover such as Novus #3,2,1 or Meguiar's. If it doesn't work, clean up inside as well.
Originally posted by LEXBERG
How do you "wetsand" ????
this site might help you. http://www.mkiv.com/techarticles/headlights/index.html
also you can search some thread about this in CL.
how's your headlight? yellowish? we need more information.
