CarPro HydrO2... buy it!
#181
That may take care of some of the "streaking" people have talked about? Are you gonna keep doing the 1:3?
I just ordered my 500 ml bottle and looking forward to some fun.....
#182
Some professionals mentioned that they use it at 6:1 for routine maintenance and still see great durability out of it.
-Zach
#183
I'll definitely try out the new ratio. I still, on occasion, have problems with it streaking. The other day I mixed some up, and did both my IS and my RX from the same mixture. The IS turned out perfect, the RX has streaks. Ugh.
#184
hi zach, carpro's website says 30ml of concentrate is needed for a standard 4 door car. using the new 4:1 ratio, that means 30ml hydro2 and 120ml distilled water. so, for a whole car, we're only using about 5oz of fluid? is this correct?
#185
is there a spray bottle you suggest? i have the 32oz chemical guys spray bottle but i suspect that'll be too big. do i need to get a chemical resistant one? does the solution have issues being misted through regular spray bottles?
#186
... you can probably find small bottles like that in the cleaning aisle of some department stores, too.
#187
I only get streaking with Hydro if you don't rinse it off in time and/or if you take too long to blow dry it. Switched to the 8hp Metrovac which significantly speeds up drying time, but even with this, you'll occasionally get streaking on glass,etc. Luckily the streaking wipes right off so I never seen this as a big issue. Great product.
#188
I've unfortunately experienced that as well from time to time... can definitely be annoying.
Yes! You need very, very little product All you need is a light mist onto the panel... the video in the original post is very much over applying the product, but it was all I could find at the time to show how the product worked.
I use this 8oz spray bottle and it works great for me... I've had the same one for about 2 years now and it still makes a nice fine mist.
#190
[ You can't go wrong with either HydrO2 or Reload for quick and easy protection... the benefit to HydrO2 is that you can apply it to the entire car in just a few minutes without any additional tools/towels during the wash process. I personally use HydrO2 most on my wheels, and prefer Reload on my paint.
Also, as a follow up, before I read about HydrO2 and Reload, I was going to buy 22ple VM1 Extreme Rim and Metal Coating. Do you have any recommendation of one over the other? Apparently the 22ple product lasts longer, but other than longevity is one better than the other?
#191
22ple VM1 is a completely different class of product and not really comparable to HydrO2 or Reload.
HydrO2 and Reload are silica based sealants which last a few months in most applications.
22ple VM1 Extreme is a coating which will last years in most situations while also being more chemical resistant and considerably thicker than a traditional wax or sealant.
Comparing Reload vs HydrO2, I greatly prefer HydrO2 for wheels but prefer Reload for paint... actually I don't use Reload much any more. I started using 22ple VS1 Final Coat which is their silica based spray sealant.
Let me know if you've got any other questions.
-Zach
-Zach
#192
Thanks Zach, you got your answer in just under the wire. The sale ends tonight!
I'm going to go with the 22ple VM1 Extreme Rim and Metal Coating for my wheels. I'll get the Reload for the paint.
I had ordered the 22ple VS1 Final Coat to apply after I used the 22ple VX3 Signature Glass Coat and it did not work at all on either my LS or 612. I had a terrible time trying to apply it and then get it off. I consulted with Adam at Detailed Image and in the end he credited me with the VS1 purchase (excellent customer service, that's why I'm a confirmed customer).
If you pick this up in time, what quick detailer do you recommend after a gentle wash?
#193
I'll try to make a video on VS1 in the future. The key is to use very little product and it is an absolute breeze to apply. Just a word of warning, Reload can also be very finicky to apply if used incorrectly. You also need very little product. Excess product usually results in smearing or streaking that can be a real pain to wipe off.
-Zach
#194
I see D155 on DI, but I don't see D156.
I know I used very, very little VS1. I know when I used the VX3 Signature I had more left in the bottle than the expected amount.
#195
Never mind, I found it. I wasn't looking for a one gallon jug.
Thanks for all the help Zach!
