CarPro HydrO2... buy it!
#271
I've got both ech20 and reload on order right now. I'll most likely mix a 1:1:20 ratio to start considering I just applied Hydro2 last week. But if all goes well the next batch I will step up the reload and see how it goes as well. Either way I like the idea of having the waterless wash I'm sure I'll mix down a separate bottle of that to detail a not too dirty of a car.
#272
Just wanted to post that I've been using the "blue juice" mixture of 1oz. echo2, 2 oz. of reload, and 20 oz of distilled water.
And the results are absolutely amazing.. I spray my mf towel to get it moist and then spray down the panel itself.. wipe 90% and then flip over MF towel to dry side or use a new one.. I usually spray the new MF with just one spray so its not dry MF on my paint.
I was also wondering - when it comes to polishing your car when Hydro2 is applied.. Do i just polish right through the hydro2?
There are a few small spots that got missed/ I would like to touch up a bit more but I just applied Hydro2
#275
In theory if the coating is still there then no reason to paint correct. You can polish out the coating same as you would the clear coat. I have not found the need to yet but I'm careful in my washing technique.
#276
Yeah my issue was a few spots got missed during my paint correction.. I noticed a few spots I'd like to touch up with some polish but i've since applied hydro2. I'll be ordering a porter cable DA polisher this week sometime and give it a try shortly after I get it.. It could have been me that caused the swirls with a MF towel wiping off the panels although I'm always gentle.. obsidian so soft such a pita
#278
I’m bringing my caviar for its first wash and hand wax. It’s the $100 package from a detailer with good reviews. I wonder if for a modest sum I could get him to also apply this product, and if so, should I?
would it go on before or after the hand wax?
For $65 you get a spray rather than hand wax. Maybe it’s enough to do this?
Thanks.
Thanks.
#279
You would want to apply Hydro2 before a wax.
The wax will likely remove it though. The point of this product is It replaces a wax.
SUPRATRD
Club Lexus Vendor Marketplace
55
02-03-10 09:40 AM
Slooooooow
03-05-09 01:48 PM
