HELP - Paint on my seat
I'm hoping someone can help with this!
Yesterday I was at a construction site and somehow my coat must of rubbed against wet paint or something of that nature. Of course I didn't know until after I sat in the car. Now I have this white stuff on my seat and have NO CLUE what to use to try and get it out.
HELP!!!!!!!!!!!!!
I don't want to ruin the leather but I don't want to just leave it.
Can anyone please shed some light on this for me.
Thanks
Claud
HELP!!!!!!!!!!!!!
Thanks
Claud
Leather Cleaner
Guys check out www.leatherique.com. Their leather cleaner should do the trick for you. Good luck.
Lex Rules!
Lex Rules!
For the ink some isopropyl or denatured alcohol or hairspray (Aquanet etc. ) should work. Lysol does too, but try it in an inconspicuous area first.
Don't use any solvents such as Goof Off etc. as most leather has a clear protective coating on it that might dissolve with such a solvent. ( probably would).
For the latex paint, ; Warm soapy water (Murphy's Oil Soap is safe) and that should do it. If not, try some baby oil. Just don't use a stiff brush if you brush it. Better to let the above solutions soak, then rub lightly with a cotton cloth. Use a leather conditioner afterwards. Good luck.
Try the above first...
If they don't work, then check out :
http://www.mrboots.com/general_store...emcav-srm.html
I found some at a local boot shop. Works well on rubber type scuff marks.
nighthawk
Automotive Care & Detailing
05-02-07 06:10 AM
