Coating/film on chrome trime.
I have never dealt with this. On my rear bumper the thin strip of chrome trim has always been more of a dulled whitish silver/light grey, I rubbed it once or twice with a chrome cleaning product and it made no difference so I figured that is just how the piece was. I had never really paid much attention to it because I have always been focused on the paint. Now I have noticed whatever was on it has flaked off in several areas on one side and what do you know their is fresh chrome trim underneath. It is like some kind of protective finish/adhesive/film was on the chrome trim that was never removed that somehow got baked on or and only now it is flaking off. Now I have to do something because it is unsightly but I am unsure how to get the rest off as the majority is still on there like it is baked on. I think if I try scrapping it off it will take forever and I will end up scratching up the chrome trim.
Has anyone had any experience with a strange film on their chrome trim that would not come off and how to remove it, any chemicals, scraping process, etc?
I'd like to see some photos... this could be due to many things.
Before you go wiping chemicals on the trim, I would make sure you understand what you are working with. Is the trim metal coated in chrome? plastic covered with a chrome look? was it clear coated? is the residue from adhesive or coating failure?
My advice would be to do some more investigating to see if you can provide more info on what you're dealing with so we can help to provide more accurate options on how to handle it.
-Zach
-Zach
-Zach
-Zach
Here are some pics, it really seems like some protective adhesive/sticker that was never removed and got baked on, top is a very light grey, bottom part is white until you get to the chrome trim.
It is not polish, it is some kind of adhesive/sticker protection that was originally on the trim that was never removed and seems to have been baked on. It has been on there for years, survived polished, wipe downs with alcohol, etc. Only recently has it started peeling and I noticed the chrome trim underneath.
If you're sure it is an adhesive, then I would start with a solvent that would remove adhesive residue. Something like 3M Adhesive Remover (can probably be found locally) or similar. You may also need to step up to a more powerful solvent, but always test a small spot first. No point in ruining the trim in the process of trying to clean it.
Does heat make the adhesive tacky/pliable? Would that help to remove it.
-Zach
Wow - very interesting looking.
-Zach
-Zach
I have not tried, not sure if I want to risk breaking it or going through too much trouble for something like this. I may dedicate a couple hours to trying to peel it off and see what happens, the other side is not peeling at all and is really on there and is going to be really tough to remove.
I tried using a soldering iron, was not working and it was burning the chrome trim, tried picking it off and that was not working once I got all the loose flakes off. Really irritated me that someone could be so careless to just leave the protective seal/film on for the chrome trim and the results is it got baked on. Not sure any chemical will work. I am either going to get new chrome trim or I read about a chrome sticker roll that you just put over top of the trim, I think you can get it at Pep Boys and other auto shops.
mcolommena
GS F (2016-present)
55
06-04-18 10:28 AM
RoMiLex
10-08-14 09:38 PM
