CarPro Perl not bonding with tires?
So i purchased CarPro Perl after reading everyone's excellent reviews on the product. However, it does not bond with the tire. Prior to applying, I thoroughly cleaned my tires with tuf shine tire cleaner and brush. On a stripped and dry tire, I applied the Perl at 1:1 with a new foam applicator and it just kept streaking off and not bonding with to the rubber. I then thought maybe i didn't clean my tires enough and there is still some solvent from previous dressings. So i cleaned again with tuf shine and apc. Same results. When the Perl dries, there is a satin look to the tire but its kond of blotchy and looks as if ot os not evenly spread. Is there anything i'm missing? FWIW, the tires are B'stone Potenza RE760
I've tried spraying it on and wiping it on with a foam applicator, but it just streaks and runs off the tire. im not sure how else to apply it or how to make it bond with the tire.
You spray a few sprays to the foam applicator and massage it in with your fingers. The key then is apply it thin to the tire and spread it around, use another cheap microfiber cloth to lightly remove the excess. Wait 30 minutes for it to dry and then you can drive your car. It works for me.
When you say it does not bond to the tire, there is a high possibility that the tire has not been cleaned properly. I would imagine a bunch of silicon gunks/junks from other tire dressing is still on the tire that causes the bonding issue. You need to at least use some All Purpose Cleaner (APC) to thoroughly clean your tire before you apply Perl or any other tire dressing.
Not too sure I know what to tell you... I would contact CarPro for some more advice as they surely know the product better than anyone. Have you tried it neat (undiluted)?
I use it regularly on my own vehicles as well as customer's cars and it has produced a great finish every time. I tend to use it neat as I have found that produces the shine I like and better durability.
![](http://i76.photobucket.com/albums/j24/AttentiontoDetailingPeoria/2013%20Camaro%20ZL1/11103218_531460863658704_3559335777014360625_o_zpstu1hfw1w.jpg)
![](http://i76.photobucket.com/albums/j24/AttentiontoDetailingPeoria/Detail%202005%20Subaru%20STi/20130810-DSC_3431_zps5128cc88.jpg)
See what CarPro can recommend
i have thoroughly cleaned the tires twice with tuf shine and apc. There is no left over gunk on them as i vigorously rubbed a mf towel on the tire to see if it picked up any left over silicone and mf turned out clean. i have not used it undiluted...will have to try that next. Im sure it has to do with my tires, not the dressing but I'll keep troubleshooting.
I don't understand this at all. Tires are all rubber anyways and Perl bond to all kinds of rubber that I have tested on. Trim, tires, even rubber parts inside my house lol. Sound like a call to Corey is a must here for him.
OP, please try Perl undiluted and report back.
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x2000/image_904b83a5e57b92319a2d46444a7b5dd4ca66ece2.jpg)
Bad pic but it's Perl undiluted. Kind of a mistake because it was too runny. Looks good tho.
Worst case just use it for your interior? Maybe it doesn't give you the look you want.
Update on Perl, after a car wash with Reset, the pearl is almost gone. It lasts me total 8 days to be exact while Tuf Shine lasts me several months going through various car washes without problem. Also, Perl is not dry to touch even after letting it cure for 12 hours while the Tuf Shine is literally dry to touch.
Perl has a darker and richer look than Tuf Tire Shine and a lot easier to apply. Perl can bond to dirty tires without problem.
Anyways, I'm happy with both products but I still prefer Tuf Tire Shine for its crazy tough durability and easier maintenance without weekly application.
While the shine of PERL does fade quickly, you'll notice the hydrophobic properties are still in tact.
I personally dress my tires every 3-5 days to maintain a deep, dark finish, however PERL makes them much easier to clean as dirt rinses off without the need for major scrubbing.
If PERL is not dry, take a towel and gently wipe the surface to remove excess product. This goes for all tire dressings.
thanks for the replies fellas. i have not yet had a chance to apply perl undiluted as i have not had time to wash my car. I do like the way perl looks however, that is after 2-3 coats at 1:1. Because like i said before, 1 coat gives me a blotchy look. And for the record, my tires are as clean as they can be. So after applying the 1 coat with a foam applicator, the perl dries on the tire and looks like water spots on paint (best way to explain). Silicone based dressing look like they bond better to the tire w/o actually bonding as it just sits on the surface. I want to keep using perl and transition away from solvents, i just dont seem to be having the success u guys have with perl.
