Best product to use?
Some **** scraped against my rear bumper and left what looks like white rub marks. What product would you folks recommend I use please?
Thanks in advance
Thanks in advance
Do you have photos?
If the damage has penetrated the clear coat, the only way to repair it is to have the area repainted.
If (hopefully) the damage has not penetrated the clear coat, it can be repaired through a paint correction process... and depending on the severity may even require some sanding.
If you do not possess a dual action polisher, you can simply purchase some rubbing compound and polish and attempt to remove the damage by hand. This is a tedious process though, so good luck... hopefully the white marks are simply material transfer and not scratches through your paint.
-Zach
-Zach
