Car covers
Car covers
I'm not really a fan of them for outside, but I really don't like the sun beating down on the car either. Surface temperature measured at 160 degrees F today in the area between the moon roof and windshield. At least its a good backed on finish at that temp. So I got a cover to try. It does have a wax job about a month ago. So just looking for others thoughts on this. Its a 90 ls400 and paint and body not perfect but is okay.
The cover is a made in us Budge 5 gold star and was about 80 some bucks.
The thing about car covers is that they will induce clear coat marring if the paint is not clean prior to using the car cover. So you need to do your due diligence to keep the paint clean as well make sure there is no debris on the inside of the cover prior to putting it on the car. Also, windy conditions make using a car cover very difficult. For an example: I had a external CCC for my mkii mr2, which had to be stored outside for a week a few years back. The cover had multiple tie down straps/ cables to keep it in place. There was a nasty wind storm one day and I came back home to find the cover had flipped half way around the car. The straps did a number on my clear coat of one of the doors.
Former Sponsor
I would recommend you Coverking Silverguard car cover. UV rays, water, extreme heat, moderate snow, rain and dirt won't be an issue. This cover is manufactured of polyester-woven fabric and covered with silver coating for UVR-protection. The rugged material delivers unique protection, yet staying soft to the car surface. Your car's finish is safe from moisture and mold due to polyurethane coatings that show high resistance to water and breathability of the material that will let any moisture dry out: http://www.carid.com/1990-lexus-ls-c...r-3372851.html
