Advice On Removing Water Spots From Glass
I have a problem with water spots on the windshield and other exterior glass after washing car. I get water spots and cannot get them out with windex or a couple other glass cleaners I have tried. I polish the glass with a dry cloth and paper after cleaning but the water spots remain.
Does anyone know of a product or method for removing water spots after washing a car?
Thanks for any advice
Ron
Ron
A guy at a local detail shop swears by a cleaning product called "Barkeepers Friend", I have not tried it myself but it is something I plan on trying. I'm not sure of the abrasive properties of it, since I use it to clean my stainless steel cookware (it is great for that) so I would use light pressure and rinse well.
You can buy this stuff at your local grocery store too!
ron,
First try a 50/50 mix of vinegar and water. Many waterspots are easily removed with this solution.
You may also try Clay Magic or some other brand of detailers/overspray clay. I clay my windshield a couple times a year. It really cleans away many contaminants, and will improve vision and wiper performance.
You may see great results with less aggressive methods before resorting to abrasive products.
Good luck.
Good luck.
windex is no no (amonia).
vinegar/water is often recommended, old school even use newspaper to wipe.
i'd recommend invisible glass by stoner. u'll be be more than happy w/ the results
[QUOTE]Originally posted by Legends6spd
[B]windex is no no (amonia).
I've used newspapers before, they work good but you have to be careful because some cleaners will transfer the ink from the paper to your glass! not a big problem but a PITA. Plain white paper way to go.
-c
-c
OK guys, here is my decision. I am going to start with the vinegar/water mix. Daddy-o has often given me right-on info so I am going to try his method first. If that does not solve my problem then I will work my way through the other recommendations. I will put everything to the test this week-end and will report back Monday.
Thanks again to all that contributed.
If anyone else has some recommendations please feel free to contribute.
Ron
Ron
Here is the promised report. I used the 50/50 vinegar/water solution and it worked great. Can't even tell a windshield exists.
Again, thanks Daddy-o for the excellent tip.
Ron
Ron
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
This is going to sound a bit crazy, but what kind of vinegar do you recommend?
I'm assuming NOT wine vinegar / balsamic
but would you recommend using white vinegar or normal apple cider vinegar? I've usually used the white variety for cleaning stuff like coffee pots, etc.
Yes Dave, I used white vinegar with a 50/50 water solution. Saved me a lot of time because you only have to clean the glass once and it is CLEAN> I removed the mix with paper towels.
Ron
Ron
what do you guys put in the windshield washer reservoir? water? windex? could you put vinegar/water in there?
Just curious..
Just curious..
The best product I've used for glass cleaning is made by Stoner called "Invisible Glass"
This has been the best product I've found to clean glass of ALL waterspots, debris, etc. It does what it says! The glass is sooooo clean!
You can find out about it from Stoner at:
Stoner Invisible Glass
Just follow the directions, and you will have glass as clean as can be!
Hope this helps,
Regards,
Deanski
Hope this helps,
Regards,
Deanski
cicio
Automotive Care & Detailing
04-01-17 07:40 AM
