To Cover or Not to Cover?
I just got a used Lexus in great shape. Where I live I don't have a garage or carport. It will not be my daily driver and am wondering if any of you cover your car with anything or what you use to protect it from the elements. It may sit still for 5 days at a time.
I am not a big fan of covers. I hear too many bad stories about them. Have you considered getting the car sealed? I park my car outside a lot and blast the car with some water before I drive. It repels a lot of dirt and the car looks clean again.
I think covering is okay if you use multi covers. I cover a car using a semi custom car cover with the car washed before its installed. Then a plastic tarp over it with a layer of something to insulate it on the plastic, then another tarp over again. The trick is to insulate from drastic temp changes and condensation. And always have a clean and waxed or protected paint on the car before the first cover goes on it. I think a cover is way better than hot sun and uv beating on the car daily, with out a cover its constant dirt and bird crap that you deal with. And the covers will prevent other damage as well like small rocks or dirt from weed eaters and lawn mowers. Oh and the most important thing to do is stop cover movement, I use a cut up truck bed rubber liner as weight and a strap as well as bungy at points under the car as well as some spring clamps to hold the plastic. I plan on getting a good vinyl custom trucking tarp at some point and that would be the #3 upper tarp. If a car sits for extended periods this is a great way to not have to wash the car all the time especially where it is real dry this summer.
Have several 'outdoor' vehicles, including a 2003 Super Duty that has been covered from the California sun and occasional inclement weather since day one. The paint and interior looks like the truck is brand new. Sometimes sits for weeks at a time without a worry. I do use a long bungee cord across the bottom to keep it taught in the wind.
I have a car that sits half the year I'm using a Noah Block-It (made from Kimberly Clark fabric) the protection is outstanding. No scratching at all and no moisture build up problems. The car can sit for 3-4 months and when I remove the cover the car is pristine.
So I'd say the reports of scratching or damage from using a quality car cover are not true.
The cover I use is called Budge and is made in US, it seems like its similar to Lexus2000. My reason for covering the cover is to protect the cover and the extra shielding it offers. Scratching only happens if there is dirt on the car and constant movement of the cover any cover will abrade. Good wax or coating is a huge help.
