Best & Safe Wheel Cleaner and Tire Shine
I bought a new 2015 Lexus ES350 a couple months ago and the tires and wheels looked so nice from the dealership. Now that a couple months have passed, the wheels no longer bubble up when washed and the tires have lost their wet shine look.
I hand wash my car every few days and would like to keep both my wheels and tires looking like new as well.
What product is safe on my wheels and will work the best for cleaning and protecting them and which product should I use on my tires?
Many thanks for any help offered!
Auto Detailing Master
For tires, I like the Tuf Shine TIre cleaner and Tire Brush.
If you wash your vehicle that often, you won't need to use a dedicated wheel cleaner. Soap and water will be just fine.
I recommend the EZ Detail Brush & Wheel Cleaning Brush to help safely clean them.
As far as tire dressing goes, you'll want to use a water-based dressing to help keep your rubber looking good without harming the surface. I personally prefer CarPro PERL for my tire dressing. It can be diluted to your preferred level of gloss.
My Go-To Wheel and Tire Cleaning Products by Zach McGovern
Product Review: CarPro PERL by Zach McGovern
Hope that helps
-Zach
Hope that helps
-Zach
美少女戦士セーラームーン
Zach's recommendations are excellent choices. He's an expert on detailing.
I personally use Chemical Guys Diablo Wheel Gel and Sonax Full Effect for very dirty wheels. Since you wash your car often, soap and water should be fine, like zmcgovern4 said.
For tire shine, I prefer to use water based tires shines like Meguairs Hyper Dressing and Chemical Guys Silk Shine. Use a good tire cleaner like the Tuf Shine Tire Cleaner with a good tire brush before putting a dressing on.
Croftgate Tire Shine
I've got some CG Diablo Wheel cleaner but I feel like it doesn't work good at all. Did you dilute it 3:1? I spray the rims down with water then I spray CG onto them and let it sit for like 10 minutes. I feel like I have to agitate it a lot more with a brush as opposed to what I previously used (meguires hot wheel cleaner)
as for the tire dressing, i currently use Perl as i prefer a water based over silicone. Perl is great bit its not as glossy as id like it to be even after a couple coats and using it straight (not diluted).
I plan on using HD Dress next as i hear great things about it and its very cheap as well. Its about $32 for a gallon and can be diluted for a more satin look. I will be purchasing this in the future.
Another thought I had in regards to protecting your wheels....
How do you think using the same Wolfgang Fuzion Carnauba Polymer Estate Wax that I use on my car's paint would work on my wheels after cleaning them with the Sonax Wheel Cleaner Plus?
Best wishes,
No Regrets
Best wishes,
No Regrets
Best wishes,
No Regrets
Best wishes,
No Regrets
I highly recommend CarPro HydrO2 as the quickest and easiest way to seal your wheels.
CarPro HydrO2: Seal Your Wheels in Less than 1 Minute by Zach McGovern
-Zach
You can certainly use a traditional wax on your wheels, it just won't likely live as long on them as it does on your paint. Your wheels take a beating in terms of dirt and debris which takes its toll on the wax.
-Zach
-Zach
Thanks for the reply. I ordered a bunch of stuff from Detailed Image that should be arriving today via FedEx....Sonax Wheel Cleaner Plus, Optimum Car Wash, DI EZ Detail Brush, CarPro PERL, Tuf Shine Tire Cleaner, etc but forgot to order the HydrO2 that you had recommended to me earlier That's why I was wondering if the Wolfgang Estate Wax would work well or not. I'll get some HydrO2 on my next order.
Thanks again for the tips and advice in helping me keep my new car looking sharp!
Best Wishes,
No Regrets
Hope that helps
-Zach
Hope that helps
-Zach
Hope that helps
-Zach
Hope that helps
-Zach
caddyowner
Great Lakes
03-27-11 05:21 AM
