Waterless wash & wax ?
I would suggest not.
These water-less products have been out for years. I am a firm believer is washing a vehicle gently to remove road dirt which contains abrasives prior to waxing. You will be abrading your finish with this product.
Auto Detailing Master
Rinseless and waterless washing can be safe when used within the appropriate limits.
The product the OP is referring to is a waterless wash, meaning no additional water is needed... no buckets, no hoses, no more water. The idea is to liberally spray the paint with the product, then wipe the surface with a high quality microfiber towel to remove surface dirt. In theory, the waterless wash will attract the dirt and provide lubrication so the paint is not harmed, however in my experiences this is only achieved when either 1) you use so much product that you might as well have just sprayed the car down or 2) there is only a very, very light layer of dust on the car and you still need to use plenty of product for lubrication.
Most people simply attempt to use these waterless wash products when the vehicle is just too dirty, and therefore scratch the paint. Likewise, there are plenty of people who simply use a quick detailer in between major washes... this is a similarly dangerous scenario.
I have found the quickest and safest way to wash a vehicle without having to drag out several buckets, hoses, etc is rinseless washing with Optimum No Rinse (or similar). Rinseless washing utilizes a bucket with some rinseless wash solution, but no need for a hose or running water to rinse the vehicle after washing. Simply use a high quality towel or wash mitt to wash a section, then immediately dry it. Note: if the vehicle is particularly dirty, you should either visit a coin-op pressure wash or drive through a touchless wash to remove the majority of the dir, then finish with a rinseless wash to make the car pristine.
I plan on going over this in detail next year in a series of videos.
-Zach
-Zach
I go to the pressure wash about a mile from my house. I drive it home and then I fill a bucket with soft water and wipe it down with a wash mitt. Next I use micro fiber towels and dry it off using as light pressure as possible. This method works for me on my 14 RX Stargazer black paint. I use a separate rag for door jambs & wheels. If you look closely at your paint after using a pressure washer you can still see a light film of dirt on the surface. I like to use this method since I don't have soft water going to the outdoor faucets.
And to think years ago I thought a genuine chamois was the only way to dry a car. Not anymore since microfiber came out. I think a real chamois causes too much friction on the paint.
Winter Washing with Optimum No Rinse (ONR) by Ivan Rajic
I used ONR for the first time last weekend on my moderately dirty Tacoma. The stuff is amazingly slick...and like Zach stated, the dirt is caught by the washmit rather than the suds as with standard shampoos. From what I could tell, it did not create any additional marring on my clear coat. With that said, I watched a few Youtube videos to get some tips. All in all, it's some amazing stuff and certainly saves your hands from exposure while using cold water during the Fall/Winter months.
