Glass Scratch Cleaner
I was wondering if there was any product out there that would remove scratches from my windshield. After 10 years of wipper blades rubbing against it you can see the track marks of the wippers when you look at the windshield at the right angle. Any suggestions?
Sounds like you're talking about your 93 LS. You can try filling your windshield fluid reservoir with Rain-X fluid. I don't know if it will totally eliminate the scratches, but at least it will help clear up your windshield from old minor pits and nicks, plus leaves a wax-like coating on the glass.
Bon Ami - has the consistency of talcum powder; very fine. It will help polish your glass, and remove the dirt in the scratches that make the scratches less visible.
1.) Use a wet washcloth / rag, sprinkle some product on the rag, and buff it onto a wet windshield.
2.) Use another clean wet washcloth to wipe off the product
3.) Use another clean dry washcloth to dry the windshield
You should be very happy with the results.
< $1 at your local WalMart.
