Anyone W/Chemical Guys VSS Experience
So I was browsing YouTube for how to remove hard water spots on Windows and stumbled upon the video where chemical guys use their VSS product on a 370Z to remove swirls in the paint. I know they are professionals and are good at what they do but has anyone on here tried this product? I would like to hear from someone who has been detailing for a long time and has many many hours of detailing experience. Thanks in advance.
So are you looking for something to remove water spotting on your glass or remove swirls in your paint? Personally I am not very fond of most Chemical Guys products other then some of their shampoos. I would stick to Meguiar's M205 as it would work fine for polishing glass to remove spotting and also be good for polishing the paint.
First, you need to understand what type of water spots you are dealing with... check out these articles which explain what causes water spots, the types of water spot damage, and how to remove them.
Understanding Water Spots & How to Avoid Them by Zach McGovern
Removing Water Spots by Zach McGovern
As discussed in the article, water spots may be above surface contamination which can simply be removed with a water spot remover (acid), or they may have etched into the surface which requires abrasive compounds and/or polishes to level the surface and remove the defects. My personal favorite water spot remover is CarPro Spotless. To answer your original question, any polish which contains abrasives can be used to remove water spots. I have not personally used VSS products, but I have heard mixed reviews... as Kevin mentioned, I would personally recommend something from the Meguiar's Line Up such as M105 Compound and M205 Polish.
Window Etching & Stain Removal | Getting the Most Out of Your Meguiar’s Cutting Discs by Brian Guy
Hope that helps!
-Zach
Hope that helps!
-Zach
I'm looking to do both remove water spots on my Windows and get rid of the swirls on my paint. I'm a total noob at this but thinking of picking up some equipment soon so I can do my own detailing on my own cars.
Here is a general starter kit that I recommend to many people because it is similar to what I started with, and it is a great package that can handle most any situation. Aside from using a DA machine for correction/polishing work, it also makes applying sealants and waxes simple. You can apply a sealant to your vehicle in no time with a machine!
Griot's Garage Dual Action Polisher
5" Backing Plate
3" Backing Plate
Lake Country Orange Light Cutting Pad (5.5" x2, 3" x2)
Lake Country White Polishing Pad (5.5" x2, 3" x2)
Lake Country Black Finishing Pad (5.5" x2, 3" x2)
Meguiar's M100 Cutting Compound
Meguiar's M205 Finishing Polish
These supplies are very versatile, and you'll be able to do anything from paint correction/swirl removal, to general gloss enhancing polishing, to spreading sealant, etc. All products are easy to work with, and dual action polishers are beginner friendly.
-Zach
yESman
Automotive Care & Detailing
06-17-07 02:45 PM
