Goof off on side mirror
Is it safe to use Goof Off for removing one of those stick on convex mirrors? I need to replace the convex mirror with a bigger one and move the location from the outside edge of the mirror closer to the window side.
TIA.
TIA.
I my experience WD-40 also works good on removing adhesive without causing any damage. I let it soak for approx 30 seconds and then I just rub off the adhesive. When using WD-40 just make sure you clean all of it off the surface with rubbing alcohol before adhering something new to the surface.
I wouldn't see the Goof Off as an issue, but make sure whatever you're using to wipe/rub it off is not abrasive. Avoid something like a paper towel and use a good quality microfiber.
