Razor marks from a clear bra install
Hi guys,
I recently purchased brand new NX and had one of the shop to install clear bra for my vehicle. I was happy with the installation at the time but I found some razor cuts on edges and corners while performing work on my own. The install involved using 1/2 precut & 1/2 custom kit so I was aware the film required some cutting, but I'm unsure whether all installers make razor cuts which ultimately leave marks on the vehicle.
Obviously this particular installer was careless and exerted more pressure than needed to cut the film, but I want to find out and see if seeking another installer will yield a cut-free result.
Some of the cuts:
Some of the cuts:
You shouldn't have any razor cuts.
I'm also a vinyl installer, and cuts in the paint are one of the items to be avoided when doing so. They make certain products called "knifeless-tape" so you can prevent the issue.
Just run the tape across the seam. The tape when properly done is very tight. When you rip up the edge of the thread to have it follow the cut, it will still have it's same cutting properties when travelling across the seam between panels. The tape is installed first, then the product over it so it can be properly cut.
To view what product I'm speaking of -
http://www.knifelesstechsystems.com/
I guess the installer chose to cut it with a razor as the seam is round. Anyway, what is your take on my next course of action? I am unsure whether I should get it repainted as original paint is always superior than a repaint
I very much agree with this statement... if the cuts are not "that bad", I would simply badger the installer and try to get some or all of your money back for the hassle. You may even go as far as to get an estimate on repairing the damage from a local body shop and have them pay you for the potential total, but I wouldn't consider it grounds for repaint unless they are very visible. Make sure you leave a review for the company so others are aware of the type of work to be expected. This should not be acceptable from a quality installer.
As for the mark, I am glad most of cuts are hidden behind the black plastic mold. My biggest worry is that it might start to rust if deeper cuts are exposed to rain.
As said, I would speak with the installer. Let them know what had happened. If the cuts aren't too deep, you might be able to have them polished out.
I agree with SonicMotor. I am also a vinyl installer and we use knifeless on a daily basis. Maybe in days gone by you could get away with a minor scratch here and there, but with the advent of knifeless tape, those days are gone...
Good installers use templates to cut the material using CAD. What was the installer doing with razor blade? I am up in Alberta.
Usually it costs ~700.00. All frontal, rear view mirrors, half hood, fenders, and frontal above wind shield coverage. Takes
about a half a day from start to finish. I always have it done when I take a delivery of new vehicle. Dealers over charge usually.
Body shop can take care of such damage without using paint. They use heat gun to make the cut disappear and finish with clear coat.
net4n6
GX - 2nd Gen (2010-2023)
05-10-12 12:20 PM
