Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
What pressure washer are you using?
Old 02-04-17, 02:51 AM
darylrsv4
darylrsv4's Avatar
Originally Posted by GSteg
Harbor Freight has a 90 day return policy if you do decide to return it.
You'll need to change out your spray gun in order to use the aftermarket foam cannon. The adapter is just a coupler to convert from M23 to M22 thread. Female or male end depends on which gun you go with. Look to spend around $30-40 for the gun/adapter. I bought my spray gun from Amazon and the adapter from eBay.
Can you post links of the gun and adapter you bought? Thank you..
Old 02-05-17, 11:49 AM
GSteg
GSteg's Avatar
https://www.amazon.com/dp/B0160O7TJY...ure+washer+gun
http://www.ebay.com/itm/262224364900?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I also bought the 1/4" quick disconnect fitting from Home Depot just because I rather not have to unscrew the gun from the hose every time. It's optional so if you don't want the quick disconnect, just find a gun with threaded ends.
My main issue was that my hose came with M22 x 15mm seal cone. It won't fit the regular 14mm stuff. Bring your hose to home depot and see if any of the accessories fit. If so, then you just need to buy a new spray gun.
darylrsv4 (02-05-17)
Old 02-05-17, 01:27 PM
darylrsv4
darylrsv4's Avatar
Appreciate it GSteg.
Old 03-06-17, 02:07 PM
darylrsv4
darylrsv4's Avatar
I ended up returning the Harbor Freight power washer. It was a pita to get anything to fit it. Probably pick up a Ryobi or Sun Joe unit this week..
Old 03-07-17, 09:53 PM
theory816
theory816's Avatar
A bit off topic but whenever I need to power wash I go to a local self service car wash station. I live on a hill and the soap and water just makes a big ugly scene. That said, in my experience, power washing with or without soap doesn't do very much to get the dirt off, especially on the door panels and even the rear end. For this reason, I use rinse less products by Optimum.
Old 04-04-17, 12:09 PM
2URGSE
2URGSE's Avatar
GreenWorks 1600 psi electric, works very well. $99 at Lowe's
Old 04-12-17, 08:37 AM
iandroo888
iandroo888's Avatar
I have the AR Blue Clean AR383 1,900 PSI electric pressure washer bought from Amazon with a MTM foam cannon but i had to buy the foam cannon adapter from AR. My only complaint is their wand attachments are proprietary (maybe?) i believe and not the standard type of screw on attachment. it has like a wing type of insert taht goes into the gun where u have to press and twist so it locks in. Otherwise, machine has worked perfectly for the past few years ive had it. Made quick work of doing a quick wash on two cars the other day.
Old 04-14-17, 11:06 AM
sydtoosic
sydtoosic's Avatar
what ^ Z said... i have the same PW as he does...
liquidtek
10-01-17 06:02 AM
dorkacho
03-20-15 05:59 PM
wirelesstj
SC- 1st Gen (1992-2000)
10-19-13 09:51 PM
grindin8o8
CL of Hawaii
07-10-09 03:31 PM
Namir
09-06-07 05:23 PM
Quick Reply: What pressure washer are you using?
