Instrument Cluster Plastic
Hello Club Lexus,
So I have a 2016 is350 and the problem right now is that my instrument cluster is a little scratched up because I wipe the plastic with a cloth.
I thought using a micro fiber cloth wouldn't scratch it, boy was I wrong. Well tbh, its not that noticeable until I get sun glare, that is when I can really notice it.
So I was wondering if anyone got the dealership to replace the plastic, or if its even possible or has some tips and tricks to get rid of those small scratches.
Thanks,
Thanks,
Hello Club Lexus,
Thanks,
Thanks,
I did a quick search and it seems that some people have had luck with their dealership replacing them for free, so I would definitely check with your dealership first. If they aren't willing to do that, the dealership should be able to get you a replacement part. That plastic cover shouldn't be too expensive.
And yup, a duster works well to keep scratches away.
drives cars
Just get a Swiffer duster, or equivalent. I basically just use Swiffer dusters to clean the dash, etc., except for occasionally needing to use a damp cloth to wipe down the door panels/plastic trim pieces when they get dirty.
Not sure to what you're referring - definitely don't use a gas duster!
drives cars
Edit: Apparently others in this thread have seen some success with compressed air/gas dusters, so feel free to give it a shot, but I have never found a reason to.
For regular maintenance, I'll take a can of compressed air to blow away the dust and bigger particles off the screen. When it comes time to actually clean it, I use a good microfiber towel and Plexus. Plexus will help remove scratches and prevent dust buildup a bit. Great stuff.
spinedoc
10-18-01 08:08 AM
