WHOA - clay bar
Lvangundy – totally agree – I bought my first one along with an order of Zaino goodies – didn’t know any more than what Sal Zaino said. Really deep cleans the paint. I used it on my old ’92 SC4 and now on the GS and I wouldn’t want to do without clay any more. It’s almost a secret, except for the detailing crowd. Probably most of the guys on here haven’t been exposed to the benefits of CLAY! Spread the word!
Do you use the clay on the bumpers and other non-metal surfaces?
Thanx Daddy.
Cadd, I think you have to wash it with dishwashing liquid to remove all the wax then clay..
Can you clay without washing with dishwasing liquid?
I wash and rinse.
I then start again with a fresh bucket-o-suds, a clean mitt and clay.
New clay for the paint and the last-used clay for the windshield.
Car shampoo makes great clay lube
Originally posted by Cadd
Is there an advantage to use dishwashing liquid to wash car before claying?
Guest
Posts: n/a
I just noticed when I clay bar'd the hood section it left a bunch of small vertical scratches. It could have been the mitt I used to quickly clean that small section or my drying chamois.
Maybe there was so much road debris there the bar got dirtyand ended up scratching the paint.. how often do you flip / squish the clay bar?
Search Function Inc.
I used claybars before but it can not beat the professional buffer. Besides you constantly need to worry about lubrication and scratches. I only use it to remove some dried out dirt from paint.
That's something that should be mentioned more when it comes to clay ; Indeed ,claying CAN be risky if you're not careful( sometimes even when you are), and most beginners will wind up applying either too much pressure, not using enough lubrication, or failing to knead the clay when it starts to get dirty. It's not an exact science unfortunately, there are many subjective decisions to make while doing it.. One other thing is to ALWAYS wash the car (I know you did this, just mentioning it again for the masses) FIRST to get the loose stuff off the finish, otherwise you'll contaminate your first bar of clay in very short order, and get scratches in the process.
Even then, all it takes is 1 single grit of sand or dirt in that clay to scratch the paint, so light pressure and kneading the clay after it looks dirty is necessary. No one can really say to knead it after 1 panel, 1/2 panel, etc. ...it all depends on the severity of the bonded contaminants. The best rule of thumb is to knead it over itself every few passes to be safest. Remember; always cut the clay into ( 3 or 4 or ?) pieces so you always have a fresh clean piece in the event you drop a piece, or when it loads up with dirt.
It's not a lot different than washing your car, because if you're not careful you can scratch it then too.
You might have to use an abrasive to remove the scratches. Meguiar's Scratch X might help before you break out the heavier compounds. Good luck, it's all a learning experience.
