How to care for new paint
Again, the key here is your car is not all gunked up with dirt and mud, etc. If it is indeed very dirty, he told me to perform a mild hose wash and do not do full power as the water jets can also scratch the car once it hits the dirt.
Max707 (10-11-17)
I spoke to a guy who owns a detailing company. He told me that the best way to clean your car (assuming your car is not very dirty) is to just use water-less hand spray. He indicated that the top reason you get swirl marks on your car is not from the washing but actually from the drying. I bought a concentrate from Auto Geek and started cleaning my car by just spraying it with the diluted concentrate and lots of micro fiber towels. So far so good.
Best is subjective, but I agree that a lot of the swirls happens in the drying process therefore it helps to use a drying aid, I just don't feel the surface is as slick with the soap or waterless concentrate. With the drying aid and towel it also helps pickup any dirt that you may have missed on the first step and flip to a new side as necessary. It also helps tremendously to use a distilled water mixture, especially in the sun.
You can blow your hands off even with the lowest jet setting from a consumer grade electric power washer you can find at your local Lower or Home Depot, believe me I almost lost my hand this way. As long as you keep some distance and some common sense you should not cause any damage to your car and/or yourself using a power washer.
jdmJZA70
Automotive Care & Detailing
08-27-09 11:26 PM
Little_D
10-29-04 07:33 AM
