Black trim restore?
Break2 (10-19-17)
Break2 (10-19-17)
Auto Detailing Master
CarPro DLUX
Product Review: CarPro DLUX Plastic and Wheel Coating by Zach McGovern
Solution Finish
Product Review: Solution Finish Trim Restorer by Zach McGovern
GTechniq C4 Trim Restorer
Product Review: Gtechniq C4 Permanent Trim Restorer by Kevin George
... however when you emailed me, you had mentioned you simply needed to remove some dried product from your trim. A trim restorer is not needed for this. You simply need to clean the trim properly.
Degreaser, all purpose cleaner, or a solvent like isopropyl alcohol can all be effective cleaners for removing dried product from trim. Simply apply the cleaner to the trim and allow it to work, then agitate with a brush and/or towel, and wipe off. Other useful tricks are using a pink eraser on the trim (works surprisingly well in many cases), or even a Mr. Clean Magic Eraser can work very well on bare plastic trim (do not rub on paint or glossy surfaces!!!!)
Solution Finish
Break2 (10-20-17)
lexdud
Automotive Care & Detailing
10-13-08 04:29 PM
