Top coat?
You can use almost anything on top of a coated car...wax, sealant, quick detailer, etc.... but you will be covering up the characteristics of the coating with anything you apply.
Most coating manufacturers have created their own spray sealant that they recommend using on top of their coatings for various reasons...
CarPro Reload
22ple VS1
GTechniq C2
Gyeon Cure
etc.
CarPro Reload
22ple VS1
GTechniq C2
Gyeon Cure
etc.
CarPro Reload
22ple VS1
GTechniq C2
Gyeon Cure
etc.
CarPro Reload
22ple VS1
GTechniq C2
Gyeon Cure
etc.
You could be using too much product or the paint is too warm when you're applying.
From the list Zach posted, I like gyeon cure a lot, but I haven't tried them all. Lately I've been putting Carpro Hydro2 on everything because it's the fastest.
Polymer net shield is a good product, but I wouldn't put it over a coating.
I have tried all of the products I had listed in my previous post, and I have had some streaking issues with all of them at one point or another. In 98% of cases, I have no issues with any of them and really enjoy them. GTechniq C2 is one that I use quite often and rarely have issues. If you use too much product, wait too long to wipe, work in too warm or too cold of an environment, etc. you may experience finicky behavior. All you need is one light spray per section (1-2 sprays total per average sized panel, such as a door).
If you had used a shampoo that leaves some sort of gloss enhancer, wax, or anything else on the surface, it might interfere with other products such as these spray sealants. That has always been my suspicious as to what may be the cause my streaking issues from time to time.
